truck stalls and wont idle
Old Jan 19, 2013 | 07:58 PM
99ramrunner's Avatar
99ramrunner
Default truck stalls and wont idle
Ok so my truck won't idle I goes from 500rpm to 1500 and sometimes stalls out when I put it in gear, it runs good after I drive it for 30mins and it warms up but otherwise it won't idle or accelerate. I've replaced the PCM the crank sensor, distributer, cam sensor, all the plugs, wires, and the coil. And still don't know what's wrong with it, also it make a rattling noise when im driving but goes away when it warms up any advice would be great!
Old Jan 19, 2013 | 08:36 PM
97tn4x4's Avatar
97tn4x4
A failing alternator not keeping the battery charged will make it not idle right. Or just a battery that's not holding a good charge will too. Try cleaning and tightening the battery cables and check your voltage at start up.
After reading your post again, try cleaning the iac on the back of the throttle body as well.
Old Jan 19, 2013 | 08:56 PM
99ramrunner
Ok thanks! I have tried cleaning the IAC but maybe i should try replacing it?
also the truck seems to miss every now and then would a bad IAC do that?
Old Jan 19, 2013 | 08:58 PM
gdstock's Avatar
gdstock
You replaced everything that has nothing to so wtih the idle.... IAC most likely needs to be cleaned. Why woulod you replace the distributor? Did you have fuel sychn set after that?
Old Jan 19, 2013 | 09:08 PM
99ramrunner
Ya thats because the idle isnt my only problem. it has lack of power and seems to miss every now and then! and i had the distributor replaced because the cam sensor was going, and it should be cuz i had it done by my local shop
Old Jan 19, 2013 | 09:12 PM
gdstock's Avatar
gdstock
So waht about IAC and TPS? And cam sensor can be replaced without pulling distributor. But what is done is done. Did you have the fuel synch set? How is your plenum? Is the idle the only problem now?
Old Jan 19, 2013 | 09:22 PM
99ramrunner
I'm not sure I think they would have known to do that though, what is the plenum?
Old Jan 19, 2013 | 09:51 PM
See the stickied thread at the top of this forum for more information than you can shake a forest at.
Old Jan 20, 2013 | 12:52 AM
99ramrunner
Ok I see now! I'm not sure what shape it's in I just got the truck 8 months ago. But I think it might need it replaced
Old Jan 20, 2013 | 08:41 AM
dhvaughan's Avatar
dhvaughan
surging idle is most likely bad TPS. replace it.
