Tranny problems even after replacement...need help
Old Jan 20, 2013 | 07:36 PM
lovettoride's Avatar
lovettoride
Default Tranny problems even after replacement...need help
Ok so a few months ago i traded a jeep cherokee for a 99 dodge ram with the 5.2, when i got the truck the trany shuttered fron 2nd to 3rd and the input seal leaked so i knew it didnt have much life left but i drove it anyway. After a month or so it developed a new problem. Every once in awile whail i was driving it would shift threw the gears and then all the sudden it would downshift straight to 1st and wouldnt shift untill i stoped and put it in park and shut off the truck, or drove 10mph at 2800-3000 for at least half a mile then it would shift for a lil while amd do it again, then the next day it wouldent do it at all.
So i figured my tranny was about shot so i bought a rebuilt one from a guy for 400 and he gave me a 30 day warranty but with my work schedule changing its taking me that long to put it in. But i got it in and took it for a test drive yesterday and the tranny is doing the exact same thing as the old one, the down shifting to first and then not shifting. Whuch leads me to believe that its not the actuall trans.
Any ideas on what it could be?
I need my truck its been out of commission for long enough.
Any ideas and help is greatly appreciated
Old Jan 20, 2013 | 07:43 PM
CEL on? Any codes?
Old Jan 20, 2013 | 08:02 PM
lovettoride
My check engine light is on but it always been on bc my cat is gutted and i dont have a scanner so i havent been able to check it sence i had it scanned for the o2 sencer
Old Jan 20, 2013 | 08:42 PM
stewie01's Avatar
stewie01
Most auto parts stores will do a scan for free.
Old Jan 20, 2013 | 11:10 PM
lovettoride
Yes but the closest one that will is 20+ miles away and i cant drive it that far the way it is,
Old Jan 20, 2013 | 11:12 PM
Do the key trick. Turn the ignition on, but don't start the motor, then off, three times. Third time, leave it on, it will display codes on your odometer. Write 'em down.
Old Jan 21, 2013 | 12:54 AM
gdstock's Avatar
gdstock
I am thinking TV cable and a few other things may be the issue.......
Old Jan 21, 2013 | 01:08 AM
lovettoride
Ive tried the key trick before when i had the old trans in it and i couldent get it to work, how would i adjust the tv cable?
Old Jan 21, 2013 | 01:12 AM
gdstock's Avatar
gdstock
Go to FAQ/DIY section and download service manual. Pretty simple, but be careful and do not break off the tab.
Old Jan 21, 2013 | 12:54 PM
lovettoride
I cant find the service manual, but just to cover the bases if its not the tv cable what else could it be?
