Fuel pressure should be 45 to 50 pounds at idle. It can cause rough idle if it is not high enough, but usually, it should starve for fuel at highway speeds. But a quick and easy check to eliminate it.
I would also check all the grounds. Battery to fender, battery to fra, and then engine ground to battery. Also pass side head to firewall.
Checked the fuel pressure. Its at 50 idleing. Also checked grounds. Was missing battery to frame. Made a 4 gauge wire and ran from battery to frame and no change. Still idles from 400 to 1200 and sometimes dies and still spark knocking after half throttle. Im about to give up on this piece
That still sounds like a vacuum leak... Check the EVAP system for bad hoses. Investigate the rest of the vacuum lines as well. Cruise, 4x4 engagement, and the little elbow for the MAP sensor would be likely culprits.
