compression test results (not good)
Old Jan 23, 2013 | 02:35 PM
greanbeans's Avatar
greanbeans
Default compression test results (not good)
so this is my results of my compression check in my truck
passenger side from front to back is 140 145 120 125
drivers side from front to back is 130 127 132 145
guess its cummins time for me
Old Jan 23, 2013 | 02:42 PM
redneck_ram's Avatar
redneck_ram
those numbers actually arent that bad. are those wet, or dry tests?
Old Jan 23, 2013 | 04:36 PM
In the overall scheme of things, and considering the age of the truck, those numbers are actually pretty good. Leak down test wouldn't hurt. See where it's going. Might be able to just swap heads, and bring them up even more.
Old Jan 23, 2013 | 04:41 PM
merc225hp's Avatar
merc225hp
Run some Mopar combustion cleaner though it and then re test. No not Seafoam.
Old Jan 23, 2013 | 04:44 PM
crazzywolfie's Avatar
crazzywolfie
did you do the test with the throttle held wide open?
Old Jan 23, 2013 | 06:18 PM
greanbeans's Avatar
greanbeans
Nope just used a regular ol compression tester with memory on it shows how high it went
Old Jan 23, 2013 | 06:19 PM
greanbeans's Avatar
greanbeans
Mopar combustion cleaner. Dealership item or no
Old Jan 23, 2013 | 06:21 PM
97tn4x4's Avatar
97tn4x4
You're suppose to hold the throttle wide open while doing the test. That can affect your readings.
Old Jan 23, 2013 | 06:33 PM
greanbeans's Avatar
greanbeans
Well Im bout gonna bother doing it again. Tore a band new plug wire end out of it
Old Jan 23, 2013 | 06:42 PM
merc225hp's Avatar
merc225hp
Yes sir it is, but I have found it at other stores as well just have to hunt for it on the shelves. Great product.
