- Reposted build sheet link for people wanting to know what there truck has in it
Old 05-16-2011 | 03:28 PM
Wonder if that was an option the original owner opted for?
  #52
Old 05-16-2011 | 03:34 PM
dodgeman2289's Avatar
dodgeman2289
have no idea. but i was very disapointed..
i thought that the 3.55 only spun one tire. mine spins both on a burnout. ive seen countless others that only had a one tire fire. they all had the 3.55..
  #53
Old 05-16-2011 | 03:35 PM
dodgeman2289
also my question is if i get new gears for my rear end 4.10s. will it be the same or will it more like posi?
  #54
Old 05-16-2011 | 04:07 PM
Posi is a product of the carrier, not the gears. You probably have the stock true-trak in there, which has been reported to be a bit weak, but, it IS rebuildable.
  #55
Old 05-16-2011 | 04:16 PM
dodgeman2289
Oh ok.. well in that case i guess mine needs to be rebuilt. I only get both tires spinning when i do a brakestand burnout. Any other time it just spins one. I noticed when i first got the truck i was ble to fishtail around a corner.. now i coulnt do it to save my life just one tire spins.. any idea wut i would need and how much parts would go?
  #56
Old 05-16-2011 | 04:53 PM
This is what you want.
  #57
Old 05-16-2011 | 05:08 PM
dodgeman2289
so that will work with 410 gears if i get them?
  #58
Old 05-16-2011 | 05:38 PM
In that case, the gears are irrelevant. Posi is a part of the carrier. The gears simply bolt TO the carrier. Clutchs and such for the posi action are inside the carrier.
  #59
Old 05-16-2011 | 06:16 PM
dodgeman2289
Oh. So if i rebuild it with that kit. With the 410 it should go back to the way it was? Just alot stronger?
  #60
Old 05-16-2011 | 06:28 PM
You will have better bottom end power due to the gears, and it will hook better (both tires) due to the new clutches.
Yes, I think you will like it.
Quick Reply: - Reposted build sheet link for people wanting to know what there truck has in it
