- Reposted build sheet link for people wanting to know what there truck has in it
Old 05-16-2011 | 09:47 PM
Boundstaffpress's Avatar
Boundstaffpress
Dear Justin:
Thank you for contacting the Ram Customer Assistance Center.
In response to your email, we are pleased to provide vehicle build
information as you requested. As per our records, your 1996 Dodge Ram
1500 (3B7HF13Z2TM113290) was equipped from the factory with the
following:
Sales Code Description
*P1 Premium Cloth 40/20/40 Bench Seat
ADAP Light Group
ADJ Heavy Duty Service Group
AHC Trailer Tow Group
AJKP Convenience Group
AJPP Power Convenience Group
APAS Monotone Paint
ASPP SLT Decor Group
BAZP 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKAS 11x2 Rear Drum Brakes
CBEP 40/20/40 Split Bench Seat
CGTS Driver Air Bag Only
CHEP Deluxe Headliner
CKEP Front Seat Area Carpet
CLAP Front Floor Mats
CSPS Passenger Assist Handle
CSRP Passenger Assist Handles
CUDP Mini Overhead Console
DGB All 4-Speed Automatic Transmissions
DGTS 4-Spd. Automatic 46RE Transmission
DHAS Lock-Up Torque Converter
DHKS Shift-on-the-Fly,231HD Transfer Case
DJCS 195MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
DSA Anti-Spin Differential Rear Axle
EAAC All Engines
EML 5.9L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GFD Rear Sliding Window
GNAS Rear View Day/Night Mirror
GNMP Passenger Side Sun Visor w/Mirror
GPP Power 6 x 9 Bright Mirrors
GVBC All Vehicles W/Power Mirrors
HAAP Air Conditioning
HGAP Hood Insulation
HGBS Dash Liner Insulation
JAYP Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBP Dual Note Electric Horns
JJJP 12V Auxiliary Power Outlet
JPAP Power Windows
JPBP Power Locks
JPS Power 6-Way Driver Seat
JRDP Power Driver Seat
K17P STRIPE/BADGE/MOLDING
LAAP Ignition Time Delay Lamp
LBAP Map/Courtesy Lamp
LBCP Glove Box Lamp
LDAP Underhood Lamp
LMAS Halogen Headlamps
LPEP Cargo Lamp
MBFP Bright Rear Bumper
MCTP Bright Front Bumper
MFDS Bright Grille
MHAS Black Windshield Moldings
MPBP Black Tailgate Applique
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCP Front Bumper Sight Shields
NAA Federal Emissions
NBKS EVAP Control System
NFWS 26 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMP Speed Control
NMCP Heavy Duty Engine Cooling
PW7A Bright White Clear Coat
QW7S Bright White Clear Coat
RAAC All Radio Equipped Vehicles
RBR AM/FM Compact Disc Radio
RCEP Infinity Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMP Tire Carrier Winch
TXD LT265/75R16C OWL All Terrain Tires
TZAP Goodyear Brand Tires
WDBP 16X7.0 Chrome Wheels
WLBS Steel Spare Wheel
WLYC All Steel Wheels
WMJP Center Hub
XBSS Pickup Box
XCMS Vendor Painted Cargo Box
XEFP Transfer Case Skid Plate Shield
YAAS Build To U.S. Mkt. Specifications
Thank you for being a part of Ram, have a nice day!
  #62
Old 05-17-2011 | 12:50 AM
dodgeman2289's Avatar
dodgeman2289
You will have better bottom end power due to the gears, and it will hook better (both tires) due to the new clutches.
Yes, I think you will like it.
thanks.. i gotta lot to do now.. i need that rebuild kit with 410s and i need the governerer preasure sensor + silanoid and since ill be doing that im gonna get a shift kit also.. i think with all that it will really wake my truck up.
  #63
Old 10-21-2011 | 04:26 PM
krichards6405's Avatar
krichards6405
Default Build Sheet-2001 Ram 4x4 Off-Road Pkg.
Dear Kevin:
Thank you for contacting the Dodge Customer Assistance Center in regards
to your 2001 Dodge Ram 1500 P/U Quad Cab build sheet.
We are pleased to provide vehicle build information per your request.
According to our records, your vehicle was equipped from the factory
with the following:
*R1 Premium Cloth 40/20/40 Bench Seat
-AZ Agate
ADAP Light Group
ADJP Heavy Duty Service Group
APDA Lower Two Tone Paint
AWK Travel Convenience Group
AWL Off Road Group
A07P 5.9L Engine(EML)/4Sp Auto Trans(DGT)
CGDS Front Height Adjust Shoulder Belts
CGWS Next Generation Front Air Bags**
CGZS Passenger Air Bag On/Off Switch
CUSP Overhead Console w/Trip Computer
DHAP Lock-Up Torque Converter
DMFP 4.10 Rear Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
DSAP Anti-Spin Differential Rear Axle
EAAC All Engines
EAGC All Gas Engine
GNCP Sun Visors w/Illum Vanity Mirrors
GNKP Rear View Auto Dim Mirror
GTSP Power Heated Mirrors, Fold-Away
GXM Remote Keyless Entry
JAYS Instrument Cluster w/Tach
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPBP Power Locks
JPDP Power Windows, Driver One-Touch
JPV Power 8-Way Driver Seat
KTXP STRIPE/BADGE/MOLDING/COLOR
K1XP STRIPE/BADGE/MOLDING/COLOR
LBCP Glove Box Lamp
LDAS Underhood Lamp
LNJP Fog Lamps
LPES Cargo Lamp
LSA Security Alarm
MBFS Bright Rear Bumper
MCTS Bright Front Bumper
MDAP Front License Plate Bracket
MFDS Bright Grille
MXBS Front Air Dam
NBKP EVAP Control System
NHMP Speed Control
PTLA Med. Bronze Pearl Coat
QFKA Light Driftwood Satin Glow
RAZ AM/FM Cassette Compact Disc Radio
RDZ Steering Wheel Mounted Audio Ctrls
TXNP LT265/70R17E OWL On/Off Road Tires
WFVP 17X8.0 Aluminum Wheels
WLBP Steel Spare Wheel
WMJP Center Hub
XBSS Pickup Box
XCJA 50 State FFV Emissions Order Code
XEAP Tow Hooks
XEEP Fuel Tank Skid Plate Shield
Thanks again for your email.
Sincerely,
Sabrina
Customer Service Representative
  #64
Old 10-21-2011 | 04:45 PM
stewie01's Avatar
stewie01
Dear Justin:
Thank you for contacting the Ram Customer Assistance Center regarding
your 2001 Ram 1500.
with the following:
-AZ Agate
ADAP Light Group
BAUS 117 Amp Alternator
BCES 600 Amp Maintenance Free Battery
CUE Rear Underseat Compartment Storage
DMDP 3.55 Rear Axle Ratio
EAAC All Engines
EAGC All Gas Engine
GJDS Rear Fixed Window
JJAS Cigar Lighter
JPBP Power Locks
LBCP Glove Box Lamp
LDAS Underhood Lamp
LPES Cargo Lamp
MDA Front License Plate Bracket
MFDS Bright Grille
MXBS Front Air Dam
NHMP Speed Control
RASS AM/FM Cassette Radio
RCDP 4 Speakers
TYV P245/75R16 OWL All Season Tires
TZHP Michelin Brand Tires
WD5P 16X7.0 Cast Aluminum Wheels
WMJP Center Hub
XBSS Pickup Box
Thanks again for your email and have a great day.
Sincerely,
Ralph
  #65
Old 04-03-2012 | 07:36 PM
danimall15's Avatar
danimall15
My 2001 laramie has the heavy duty service group. I got new shocks put on front to back. My truck is now even worse than before. I think they are the wrong size. Does anyone know what size to put on?
  #66
Old 04-03-2012 | 07:37 PM
Does it ride like a truck? What is it? 1500? 2500?? 3500?? What engine? Cab length? Bed length?
  #67
Old 04-04-2012 | 03:57 AM
Johnny2Bad's Avatar
Johnny2Bad
Took me 2 days from Chrysler Canada (use the "contact us" link top left of any Dodge/Chrysler Canada website) but that included a very quick reply from them asking for a full VIN because they couldn't find it with the abbreviated one, and then another very quick reply suggesting I take it directly from the vehicle instead of my records, which had a 7 in place of a T, as it turns out. I got a case number in the first reply so followups were very quick; build sheet was in my inbox a couple of hours after I finally gave them the right info.
One thing that could be a problem (not sure about the US, but definitely an issue with Chrysler Canada) is you have to be the vehicle owner on their records before you will get a build sheet. So if it's a used vehicle call customer care and get your name and contact info associated with the VIN. After that the build sheet is just an eMail away.
My build sheet indicated two recalls are outstanding.
We note that Recall Campaigns 875, Ignition Switch Wiring, and 7631,
Vapor Canister/Purge SOL, is outstanding on your vehicle. Please
contact your dealer to arrange completion of this service, at no charge
to you.
Anyone know what the 7631 Vapor Canister/Purge SOL is all about?
  #68
Old 04-04-2012 | 04:22 AM
Johnny2Bad's Avatar
Johnny2Bad
Anyway, build sheet:
Subject Vehicle: VIN # [ ...] / 1996 Dodge Ram 1500
Please find attached, as you requested, the original factory equipment
list of the subject vehicle at the time of manufacture, according to our
records.
Thank you for the opportunity to be of assistance to you.
Deluxe Cloth 40/20/40 Bench Seat
Convenience Group
Center Band Two Tone Paint
81 Amp Alternator
Driver Air Bag Only
All Engines
5.2L V8 MPI Engine
Rear Sliding Window
Manual 6 x 9 Black Mirrors
All Vehicles W/O Power Mirrors
Heater
Instrument Cluster
200 KPH Primary Speedometer
Cigar Lighter
Single Low Note Horn
Daytime Running Headlamps, High Beam
Cargo Lamp
Bright Rear Bumper
Bright Front Bumper
Bright Grille
Front Air Dam
Federal Emissions
EVAP Control System
26 Gallon Fuel Tank
Engine Block Heater
Speed Control
Emerald Green Pearl Coat
Prairie Pearl Coat
4 Speakers
2-Spoke Steering Wheel
Tire Carrier Winch
P245/75R16C BSW All Season Tires
16X6.5 Steel Wheels
Steel Spare Wheel
All Steel Wheels
Bright Wheel Trim Rings
Center Hub
Pickup Box
Build To Canada Mkt. Specifications
NOTE: Please do not use the 'Reply' function of your email. If you have
a need to respond to this email, please visit us at our reply form (link
provided below). Our system is NOT able to accept any emails at this
address.
For any future communications related to this email, please refer to the
following information:
REFERENCE NUMBER: [ ...]
REPLY LINK:
ht*ps://forms.chryslercanada.ca [ ...]
Sincerely,
K. Owen (Ms.)
Customer Care Manager
Chrysler Canada Customer Care
  #69
Old 11-01-2021 | 12:38 AM
Shockley968's Avatar
Shockley968
Default All options
Originally Posted by xxxcowxboyxxx
everybody....is my truck the only one out there with a leather interior...woodgrain everything? "regency edition"
my truck was a dealerships "trophy truck" ..... yanno, the one they they crammed everythign dodge had to offer into one truck.
just wondering if there is anyone else out there with a rare one like i have, i have never seen another one. specially being a 99 sport 1500....with cablights stock, which i replaced with smoked lenses last week. (looks sweet)
let me know, im curious
Yep. Leather,all options,diesel 2500quad sport with 118,000 original miles
  #70
Old 11-01-2021 | 10:35 AM
Nine year old thread?
Quick Reply: - Reposted build sheet link for people wanting to know what there truck has in it
