Ball Joint Mystery, Need help ASAP
Old Jan 25, 2013 | 01:47 PM
Qaiphyx's Avatar
Qaiphyx
Default Ball Joint Mystery, Need help ASAP
Replacing ball joints on a 96 ram 1500 5.2 4x4 with a dana 44, I got the replacement ones, the bottom work fine but the upper joints push out of the C when I screw in the bottom call joint, and are not the same as the upper joints that were already in there, They are longer. I have been trying all mmorning to find th proper joints, axle could have been swapped for all I know. I will try and post a picture of the joint. Need help identifying the part.
Old Jan 25, 2013 | 01:49 PM
Qaiphyx's Avatar
Qaiphyx
Here is the pic(attachment)
These are the new ones that are for a 96
Attached Thumbnails Ball Joint Mystery, Need help ASAP-2013-01-25-12.36.53.jpg
Old Jan 25, 2013 | 02:13 PM
merc225hp's Avatar
merc225hp
Some upper ball joints have a built in let's call it extension to them. Once you have it all together they will seat back in right. Can you post a part number for those and a make please.
Old Jan 25, 2013 | 02:14 PM
Qaiphyx's Avatar
Qaiphyx
are you sure it pops all the way out if I recal correctly
Old Jan 25, 2013 | 02:27 PM
merc225hp's Avatar
merc225hp
It should move in and out 1" ( the pin)but if its driving the whole bj out of the knuckle that's not right.
Old Jan 25, 2013 | 02:49 PM
Qaiphyx's Avatar
Qaiphyx
From what I observed it pressed out the whole joint
Old Jan 25, 2013 | 02:52 PM
Are you tightening the lower ball joint first?
Old Jan 25, 2013 | 03:00 PM
Qaiphyx's Avatar
Qaiphyx
Tried to compress the joint and it wouldn't, got some moog brand now and they compress just fine. Thanks!
