super slow to heat
Old Jan 26, 2013 | 07:41 PM
ZeroZero3's Avatar
ZeroZero3
Default super slow to heat
How fast is your heater heats up the cab? mine takes forever, I get to work before I can feel some good heat coming out the vents. New heater core and water pump last summer, coolant system flushed, AC system is empty and I don't remember if I replaced the thermostat since I did a lot of work on the truck last summer.
Any idea or trick? different thermostat, a piece of cardboard in front of the rad maybe? lol
Thanks
Old Jan 26, 2013 | 07:47 PM
blindsided's Avatar
blindsided
Sounds like a good burping may be in order.
Old Jan 26, 2013 | 07:49 PM
ZeroZero3's Avatar
ZeroZero3
I did burped the system many times after I replaced the water pump and I have no bubblely noise coming out of the core.
Old Jan 26, 2013 | 07:55 PM
blindsided's Avatar
blindsided
How long does it take to get to operating temp? Are both hoses to the heater core warm?
I had a similar situation, replaced the t-stat and all was well.
Old Jan 26, 2013 | 08:10 PM
ZeroZero3's Avatar
ZeroZero3
How long? way too long and I will have to check the hose next time. I will double check if I replaced the thermostat or not.
Old Jan 27, 2013 | 08:57 AM
Does the engine get up to operating temp?
Old Jan 27, 2013 | 11:12 AM
ZeroZero3's Avatar
ZeroZero3
Ok I will edit that.
Just went for a 15 minutes drive, heat is only luke warm and so are the heater hoses. It's only 12 F here and the temp gauge stayed at 55 all the way. It's a canadian truck so I am assuming that this in degree C so it would be 130F for most of you guys.
How about the temp sensors? would they play a role in this? I think I am going to go get another thermostat later today.
Old Jan 27, 2013 | 12:46 PM
You only have one temp sensor on your truck, pcm suggests to the cluster what to display. I suspect your thermostat is stuck open.
Old Jan 27, 2013 | 04:35 PM
ZeroZero3's Avatar
ZeroZero3
Not the thermostat, I just boiled it and it opens fine. It was almost new. I remembered that the coolant temp sensor was crack or loose and that I gooped it with RTV.
Any suggestion?
Old Jan 27, 2013 | 05:20 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
replace the sensor if it is cracked
if you are getting even a little heat the temp gauge should be the line after 55 so about 60-65 i am in canada so i know the feeling when it wont get hot in the cold we have up here
