1995 Dodge ram 1500 PLEASE HELP! Vibration ?
Old Jan 27, 2013 | 10:23 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
wow that was what i thought may be the issue that is screwed how did the shop not notice that when they did the joints do they not look at the surounding area thats how you keep the customers is by looking at all possible issues not skipping a very ovious one for your safety pull the shaft so it does not break before it gets replaced
Old Jan 27, 2013 | 10:26 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
No. You might be able to take it to a driveline shop, and get it replaced, but, there is no fix for those, aside from replacement. Best bet is just find a used shaft in decent condition
at the yard. Before you install it, take it apart, clean it really well, grease the snot out of it, put it back together, and stick it in the truck. Would more than likely be cheaper than getting your repaired. (in fact, I would bet real money that replacement is cheaper than repair.)
plus you already have new joints to put in from your old shaft so its much cheaper to replace not repair
Old Jan 27, 2013 | 10:32 PM
WPG1500's Avatar
WPG1500
No. You might be able to take it to a driveline shop, and get it replaced, but, there is no fix for those, aside from replacement. Best bet is just find a used shaft in decent condition at the yard. Before you install it, take it apart, clean it really well, grease the snot out of it, put it back together, and stick it in the truck. Would more than likely be cheaper than getting your repaired. (in fact, I would bet real money that replacement is cheaper than repair.)
thanks i'll check it out replace it sometime this week and write am update
here is some truck ****
Old Jan 28, 2013 | 01:39 PM
WPG1500's Avatar
WPG1500
Located a used one for 175 + tax at a local wrecker hopefully its worth the cash cause I am sick of spending.
Old Jan 28, 2013 | 02:33 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
inpsect the part before you pay and make sure for that amount it has a warenty
Old Jan 28, 2013 | 05:24 PM
WPG1500's Avatar
WPG1500
Other than the U-joints how do I properly inspect it ? honestly this truck has been learn as you go for me thus far. haha!
PS part has 90 day warranty.
Old Jan 28, 2013 | 08:26 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
look down the shaft for any bending
pull the shaft apart look at the splines on the slip goint make sure they are not damaged
90 days is resonable
Old Jan 28, 2013 | 09:42 PM
Make sure there is no slop in the slip joint too.
Old Jan 28, 2013 | 10:19 PM
WPG1500's Avatar
WPG1500
well i get paid in a few days so i will go pick up the shaft and you guys can talk me through the take down of it. lets make this thread worth the read for other who might have the same problem so far you guys have been great.
more truck ****.....
