so was there still a plastic piece attached to the shaft? also is there a broken pin in the shaft somewhere or does it look like it it missing? may almost want to take apart the distributor and see what went on?
Pin may be laying inside engone....but I don't think there is any way one could look down that hole without a flex camera. Evven a small pin could jam it up.
Crazzywolfie, is it a roll pin or solid pin? I've never had one of these out.
i am pretty sure it is a rolled pin. not sure if they changed it between 91 and 01
so did the cam still turn freely? there should have been a a plastic piece on the shaft at the bottom of the distributor case to prevent the shaft from going up. if it is missing along with the pin i might be a bit worried about where it went?
