trans... rebuild or something else
Old 01-29-2013, 09:19 AM
GTXtreme19's Avatar
GTXtreme19
GTXtreme19 is offline
these ought to do the trick right? Says HD and Borg Warner is a dang good name, in my book atleast. Is there anything better?
Old 01-29-2013, 11:21 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,276 Likes on 3,023 Posts
GM conversion, but, it's at least twice the price. The BW units are the next best thing.
Old 01-29-2013, 12:20 PM
GTXtreme19's Avatar
GTXtreme19
Thanks, ill try this before I delve into a rebuild. Then again when I pull the panill decide what needs to be done.
Old 02-11-2013, 01:22 PM
GTXtreme19's Avatar
GTXtreme19
well I got to dig in to the trans today for filter/fluid change and band adjustment. The pan had what looked parts of a snap ring in it, it was pretty beefy. I decided to go ahead with the band adjustment and hold out til summer, the band in the pan will not righten at all its moving while tightening with my fingers all the way in. I haven't tried the front band yet, my long tube headers along with weather that feels like 10 degrees is making it a pain in the ***. The band adjustment screw doesnt have the torx either its just a square maybe 9mm head that i would have to get at with a wrench, is this normal?
Old 02-11-2013, 01:30 PM
HeyYou is offline
Band strut didn't fall out did it? If you can't get it to tighten up, that indicates the band is toast, and it's time for a new one.
Old 02-11-2013, 02:30 PM
GTXtreme19's Avatar
GTXtreme19
no, the strut is still there at least from what I can tell, its not on the ground or in the pan. Guess I'll start ordering parts for rebuild.
Quick Reply: trans... rebuild or something else
