Ball Joints
Old Jan 31, 2013 | 09:23 AM
stewie01's Avatar
stewie01
Hopefully the OP will post a picture or two, so we can see what the tech did...
Old Jan 31, 2013 | 10:42 AM
h3lzsn1p3r's Avatar
h3lzsn1p3r
4wd ball joints from a 3rd gen ram are commonly substituted due to avalability at the time they are the same
Old Jan 31, 2013 | 11:13 AM
3rd gen is IFS on the 4x4's in any event, are they not?
Old Jan 31, 2013 | 03:04 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
basicaly the same setup as the 2wd just with tortion bars and different knuckles
Old Jan 31, 2013 | 03:28 PM
Rammer1500's Avatar
Rammer1500
Here's the low down... Parts manual shows Moog #K7271 for the lower and that is what was put in.. For the upper it shows Moog #K7206T, the mechanic used Moog #K3134T instead which the manual says is for a 4wd.
Old Jan 31, 2013 | 03:31 PM
stewie01's Avatar
stewie01
A picture of the top ball joint/control arm would really help.
Old Jan 31, 2013 | 03:34 PM
Rammer1500's Avatar
Rammer1500
Angry
Unable to photograph... camera broken
Old Jan 31, 2013 | 03:36 PM
Considering that there are very few differences in the front suspension between 2 and 4 wheel drive on the third-gens..... I wouldn't be at all surprised to learn that the ONLY difference between the two joints is, the 4x4 unit is a bit beefier.... never a bad thing.
stewie01's Avatar
stewie01
Oh. Well here's this, check your top control arm, if you have 3 holes were there used to be rivets, then I'd worry.
Old Jan 31, 2013 | 03:46 PM
Rammer1500's Avatar
Rammer1500
They are pressed in...
