Ball Joints
Old Jan 30, 2013 | 03:56 PM
Rammer1500's Avatar
Rammer1500
Default Ball Joints
I had my ball joints replaced recently and the mechanic used the correct joints for the lower, but used the joints for a 4wd for the uppers. Is that a problem?
Old Jan 30, 2013 | 09:22 PM
stewie01's Avatar
stewie01
Does your upper have the rivet style or press in? The ball joints on my '01 are rivet style.
Old Jan 30, 2013 | 10:16 PM
kejobe's Avatar
kejobe
It was my assumption that all the 2wd rams were rivit. But then I may be wrong since mines 4wd.
Old Jan 30, 2013 | 10:18 PM
QuadCabLuv's Avatar
QuadCabLuv
No not all were riveted. I think they started the rivets in mid 98. My 95 has pressed in and my 01 has riveted.
Old Jan 30, 2013 | 10:20 PM
kejobe's Avatar
kejobe
Aaaaand therefore my assumption was incorrect. Eh, live and learn.
Old Jan 31, 2013 | 07:15 AM
Rammer1500's Avatar
Rammer1500
They are pressed in...
Old Jan 31, 2013 | 07:20 AM
stewie01's Avatar
stewie01
Could you take a picture and post it? Need to do photobucket or the like. It would be the best way to see what he did.
If the top requires riveted style and he used a press in style I can't see how that would work unless he welded them in, but still, why?
Old Jan 31, 2013 | 07:35 AM
Twisted Metal's Avatar
Twisted Metal
The new ones are bolted in because you have to remove the rivets to change them. IIRC depending on make of the ball joint they are the same 2 or 4wd. I think on Moog has different part numbers. But, having seen and installed both, I saw no difference.
Old Jan 31, 2013 | 07:39 AM
stewie01's Avatar
stewie01
Well yes, you'd bolt in new ball joints for 2wd. But aren't 4wd normally press in?
Old Jan 31, 2013 | 08:34 AM
ALL of the 4x4 bj's are press in. If the truck required bolt in joints, and the tech put in press in joints, that is an accident waiting to happen.
