trans line check valve delete
Old Mar 23, 2013 | 09:51 PM
  #61
gdstock's Avatar
gdstock
Originally Posted by dhvaughan
....BE SURE YOU PLUMB THE REMOTE FILTER CORRECTLY TO THE (IN) PORT !!!
if you route it backwards you'll kill your trans.....
+1. Don't ask.....
Old Mar 23, 2013 | 09:57 PM
  #62
dhvaughan's Avatar
dhvaughan
that will remain as the "unspeakable".
Old Mar 23, 2013 | 11:00 PM
  #63
My360's Avatar
My360
I went over to Napa today to get the fittings for the delete, turns out Napa Canada and Napa US have two entirely different parts number list and different suppliers.
So, if I just take the check valve out and drill it out, will that work just as well? Any drawbacks to doing this?
Old Mar 23, 2013 | 11:02 PM
  #64
gdstock's Avatar
gdstock
I drilled mine out. No problems with it. Ball is plastic or rubber.
  #65
dhvaughan's Avatar
dhvaughan
drilling it out is a good fix. just be sure and blow it out clean with air or brake cleaner.
edit. scooped by gd....
Old Mar 24, 2013 | 09:03 AM
  #66
bigaaron's Avatar
bigaaron
thanks all for the input - again
Old Mar 24, 2013 | 09:11 AM
  #67
My360's Avatar
My360
Thank you, as well.
Old Mar 24, 2013 | 11:49 AM
  #68
zman17's Avatar
zman17
Retired Moderator - RIP
I just drilled mine out too. I believe I used a 5/16" drill bit.
Old Mar 30, 2013 | 07:17 PM
  #69
Timothy Watrous's Avatar
Timothy Watrous
dose the 94 year have the check valve?
Old Mar 30, 2013 | 08:55 PM
  #70
zman17's Avatar
zman17
I believe so. Open the hood and look.
