46RE Transmission Slip at 2k?
Old Mar 3, 2013 | 01:13 PM
  #41
gdstock's Avatar
gdstock
I can't remember - have you checked band adjustment? If not, get an in pd torque wrench.
Old Mar 3, 2013 | 01:43 PM
  #42
stewie01's Avatar
stewie01
I have not checked band adjustment yet, was gonna do it all together.
Actually, since I already have the BW Solenoid on the way, I may just change those out and see how it responds before messing with the band, since I don't have to drop the pan to adjust that band...
If I do it all together and my problem is fixed I won't know what the solution was.
Old Mar 3, 2013 | 11:47 PM
  #43
gdstock's Avatar
gdstock
Front band can be adjusted with pan on, not so much so on the rear..
Old Mar 4, 2013 | 12:03 AM
  #44
stewie01's Avatar
stewie01
I adjusted the crap out of the rear band to fix my reverse issue, don't really wanna mess with that if I don't have to.
Old Mar 4, 2013 | 12:16 AM
  #45
gdstock's Avatar
gdstock
Ok. Maybe it's just me, but THAT is a little scarry!
Old Mar 4, 2013 | 06:43 AM
  #46
stewie01's Avatar
stewie01
Yea, it was scary!
I had to tighten the adjustment screw a long way before it got tight.
Old Mar 4, 2013 | 03:09 PM
  #47
stewie01's Avatar
stewie01
New stuff came in today
Probably be the end of the week/weekend for I get to install it.
Old Mar 4, 2013 | 03:13 PM
  #48
zman17's Avatar
zman17
Retired Moderator - RIP
How much of the adjusting screw on the rear band (and front band for that matter )are sticking out past the lock nut? Pics please.
Old Mar 4, 2013 | 04:46 PM
  #49
stewie01's Avatar
stewie01
I'll take a pic when I drop the pan
Old Mar 4, 2013 | 07:18 PM
  #50
dhvaughan's Avatar
dhvaughan
you got a drain plug? if so you can catch, filter, reuse your expensive $6+/quart atf fluid. otherwise - its awfully expensive to needlessly dump almost new fluid.
