46RE Transmission Slip at 2k?
Old Feb 16, 2013 | 05:41 PM
  #21
stewie01's Avatar
stewie01
Alright, now that we got the wife's vehicle out of the way I can get back to the transmission problem on the Ram.
Since I topped off the fluid I've noticed that on some days it will work as it should without any problems, and other days it does as shown in the video.
I haven't dropped the pan yet, kinda don't want to if I'm gonna upgrade to the BW Solenoid (want to do it all in one round) and I don't have to drop the pan to adjust the band.
http://www.ebay.com/itm/High-Perform...7e191d&vxp=mtr is the BW Solenoid
Anything else I should consider?
Old Feb 16, 2013 | 05:50 PM
  #22
gdstock's Avatar
gdstock
Check band adjustment....
Old Feb 16, 2013 | 05:56 PM
  #23
stewie01's Avatar
stewie01
That's the plan. Drop pan and inspect, BW Solenoid, and Front Band Adjustment.
If that doesn't work I'll PM your for your address!
Old Feb 16, 2013 | 05:58 PM
  #24
gdstock's Avatar
gdstock
Check rear band while you are there. That ATF is expensive....Got drain plug?
Old Feb 16, 2013 | 06:04 PM
  #25
stewie01's Avatar
stewie01
Isn't Reverse on the rear band? I adjust the crap out of it for my reverse issue, kinda afraid to mess with it too much.
Nope, no drain plug I WILL put one in this time.
Old Feb 17, 2013 | 11:42 AM
  #26
stewie01's Avatar
stewie01
Ordered the BW Solenoid today
Old Feb 17, 2013 | 12:43 PM
  #27
gdstock's Avatar
gdstock
If you can afford to do it now, a sonax sure cure would not be a bad idea!
Old Feb 17, 2013 | 01:09 PM
  #28
stewie01's Avatar
stewie01
Isn't there a lot work involved with that?
Old Feb 17, 2013 | 01:23 PM
  #29
gdstock's Avatar
gdstock
Yes....and no. Look at section on VB in service manual. All you are doing is taking it apart, installing the new spools and springs, etc, and drilling a hole in the divider plate (or whatever the official name is...). Someone has a thread here on DF on installing kit I think.
If I ever get time, I plan to take my OEM valve body and installing a kit in it and selling it. And if I ever get the extra coin to buy the kit......Wife not working since we moved so she can take care of FIL, so being a little more frugle on project spending.
Old Feb 17, 2013 | 01:36 PM
  #30
stewie01's Avatar
stewie01
Now that's an idea!
