Sloppy Steering Fix?
Old Feb 10, 2013 | 09:51 AM
Sooper's Avatar
Sooper
Default Sloppy Steering Fix?
Found this on Craigslist this morning. I have never heard of a 'solution' like this and I thought I would run it by you guys for judgement.
http://lawrence.craigslist.org/ptd/3567999022.html
I personally don't need one, but it's intriguing enough for me to wonder if it's a real solution to a problem a lot of us have. I'm inclined to believe that a bracket and kit like this...which looks professionally done...would not be worth the effort as a scam.
Old Feb 10, 2013 | 09:56 AM
On a street driven vehicle, that would actually be a good thing to have..... but, on a truck, it can put undue side loads on the pitman (sector?) shaft and bearing out on the trail. Dodge Off-Road makes one that isn't tied across the frame, and eliminates that potential pitfall.
Old Feb 10, 2013 | 10:02 AM
CSDavies26's Avatar
CSDavies26
I've seen these discussed before, with very mixed reviews. Maybe search for "steering brace" on here. I'd be more inclined to try the rock solid ram steering fix before this one. I've also heard this cross brace thing won't work with some lifts
Old Feb 10, 2013 | 10:13 AM
Grolli's Avatar
Grolli
I have this exact one on mine. Came with it. Seems to help. The only problem is, when I replaced my steering box, the extension for the pitman goes through the bearing was rusted tight. I had to get creative to remove the entire assembly. Just food for thought.
Old Feb 10, 2013 | 10:43 AM
Ham Bone's Avatar
Ham Bone
+1 to what hey you said.
The dodge off road one is the one you wanna get.
Old Feb 10, 2013 | 11:13 AM
Sooper's Avatar
Sooper
Sounds interesting...got a link?
Old Feb 10, 2013 | 11:36 AM
oxymoron29's Avatar
oxymoron29
I made a thread about this a few weeks back. There was a lot of theory thrown around but very few real life testimonials. These brackets are a fix solely for the lateral movement of the pitman shaft when the steering wheel is turned. There are a bunch of copies of this type of support available out there with slightly different design aspects such as the center support being a tube cross section rather than an angle iron sort. I have since ordered the http://www.dodgeramsteeringstabilizer.com version and will be picking it up in a couple weeks.
These supports do in fact incorperate a self-aligning bearing that will compensate for the relative movement of the frame rails under load. I chose the http://www.dodgeramsteeringstabilizer.com support over a boxed cross section support hoping that it will actually flex and twist more with the truck rather than trying to stiffen the frame (which should never be the purpose of a support like this). With a boxed section, my theory is that the the stabilizer will be too rigid and failure will occur at the thinnest section of the bracket (ie. the mounting points).
I will try to give a review of this support when I pick it up. The DOR support looks best suited for hardcore offroaders. Since I am not, and the other support was nearly half the cost, I chose it.
Old Feb 10, 2013 | 11:50 AM
Big White Farm Truck's Avatar
I put one on my truck that is similar, mine came from Geno's Garage. I could tell a big difference when I installed it. The main idea is it supports the steering box and wont allow it to move.
Old Feb 10, 2013 | 11:51 AM
Have a look here.
Old Feb 10, 2013 | 04:17 PM
gdstock's Avatar
gdstock
Ram Rock Solid Steering fix will resolve the "clunking" in the column very well, which is what it was designed for. It will not fis sloppy steering caused by other wear and falures.
Make that +2!
