2001 1500 4x4 trans issue
Old Feb 12, 2013 | 10:53 AM
rockyram's Avatar
rockyram
Default 2001 1500 4x4 trans issue
i have a 2001 ram 1500 4x4 with the 360 magnum. i am having trouble with my transmission. ok here is the deal. when i start my truck up and its not warmed up it doesn't shift out of first. but if it does it'll slip into neutral. it also does it after shut off and turn back on to drive within an hour. when it is warmed up it shifts but shifts only at certain speeds. 12, 28, 42, and finally 50. when it shifts it shifts kinda hard. can someone please help me with some input. thanks
Posted from Dodgeforum.com App for Android
Old Feb 12, 2013 | 11:13 AM
stewie01's Avatar
stewie01
Probably wouldn't hurt to check the trans fluid level first. Check with truck at normal operating temperature and the transmission in N.
Old Feb 12, 2013 | 12:26 PM
rockyram's Avatar
rockyram
i have changed the filter and replaced the fluid. still has not helped
Old Feb 12, 2013 | 01:11 PM
stewie01's Avatar
stewie01
Was there any debris in the fluid or on the magnet? Some greyish looking crap on the magnet is normal, large chunks of metal aren't.
Old Feb 12, 2013 | 02:26 PM
rockyram's Avatar
rockyram
there was the normal dusting but no large chunks. my check engine light is on but no codes show up when tested
Old Feb 12, 2013 | 06:27 PM
How many miles on it?
Old Feb 12, 2013 | 09:09 PM
gdstock's Avatar
gdstock
If a CEL is lit, there is a code. Check with another scanner.
Old Feb 12, 2013 | 09:32 PM
rockyram's Avatar
rockyram
154k. it started doing it around 139k. and i have tried multiple scanners even high end scanners
Old Feb 12, 2013 | 09:38 PM
gdstock's Avatar
gdstock
Have to read stored codes, not just active codes. Don't know how many drive cycles a Ram takes to clear memory, but it is possibly quite a few.
Old Feb 12, 2013 | 09:41 PM
While you were in the pan, did you have a look at the governor pressure sensor/solenoid?
