Rpm
Old Feb 12, 2013 | 05:11 PM
byronpen's Avatar
byronpen
Default Rpm
when the truck thinks about starting. the rpms keep bouncing 400 to 600 for a good 10 min befog the truck idles up to were it can be driven.
Old Feb 12, 2013 | 05:20 PM
stewie01's Avatar
stewie01
IAC? Idle Air Control?
Old Feb 12, 2013 | 05:25 PM
byronpen's Avatar
byronpen
Ive replace that way to many times. that has to be good
Old Feb 12, 2013 | 06:20 PM
Vacuum leak probably.
Where at in adrian?
Old Feb 12, 2013 | 07:00 PM
dhvaughan's Avatar
dhvaughan
surging idle is usually caused by a bad throttle position sensor TPS. (not IAC). drivers side of throttle body. about $40-50 at any parts store.
Old Feb 12, 2013 | 07:08 PM
stewie01's Avatar
stewie01
Damnit!
Old Feb 12, 2013 | 07:24 PM
dhvaughan's Avatar
dhvaughan
the only reason i know is that i used to have that condition but only in a cold start in cold weather. i changed the damn iac about 3 or 4 times before it dawned on me to try the tps.
Old Feb 12, 2013 | 09:04 PM
gdstock's Avatar
gdstock
Yep. Both have to be good for a good ilde.
