Plenum question
Old Feb 16, 2013 | 09:06 PM
  #31
stewie01's Avatar
stewie01
There's great debate over those bolts. Some reuse without any issues, you can get a new set from the dealer for around $16. Cheap insurance.
Old Feb 16, 2013 | 09:07 PM
  #32
crazzywolfie's Avatar
crazzywolfie
you should have ordered a ntk. these truck don't really like Bosch o2 sensors.
Old Feb 16, 2013 | 09:12 PM
  #33
MHell2k13's Avatar
MHell2k13
Lol I changed the order thanks. Is there anyone who knows the specs of those bolts so I could get them from ace?
Old Feb 16, 2013 | 09:15 PM
  #34
stewie01's Avatar
stewie01
I'd just get them from a dealer (so you know you're getting the right bolts) or reuse the old.
Old Feb 16, 2013 | 09:28 PM
  #35
Boatdaddy's Avatar
Boatdaddy
5/16-18 X 2 1/2" long. I used SS bolts with washers, but grade 5 will work just fine. I don't buy into the hype with the supposed TTY bolts on there. But I'm new here so I'm not trying to rock the boat...
Old Feb 16, 2013 | 09:30 PM
  #36
No worries.
I can't find ANYTHING in the factory service manual that suggests they need to be replaced either..... I put new ones in mine anyway..... (considering two broke when I tried to remove them, I suppose it is just as well.)
Old Feb 16, 2013 | 09:39 PM
  #37
crazzywolfie
i removed every single intake bolt out of a intake at the junk yard without snapping a single bolt. all of them came out almost too easy.
Old Feb 16, 2013 | 09:40 PM
  #38
You got lucky.
Old Feb 16, 2013 | 09:49 PM
  #39
crazzywolfie
i know. they even had the drivers side fender off, axle out and it was sitting on the ground so removing the intake was a fairly easy job.
Old Feb 17, 2013 | 01:04 AM
  #40
gdstock's Avatar
gdstock
These bolts are not TTY. They are not hardened (part of the TTY process) and they are threaded the entire length (not possible with TTY) bolts). But I cahnged mine, purchased from dealer. They were not that expesnive, and I broke one off. Better safe than sorry, I also used anti sieze on the new one going back in...just in case I had to go back into it.
No worries.
If they were TTY, it would be specified in the manual.... ....one would think.
