2001 ram very doggy. HELP!?!
Old Feb 15, 2013 | 02:38 PM
Codynetz2001's Avatar
Codynetz2001
Question 2001 ram very doggy. HELP!?!
I have a 2001 dodge ram 1500 with the off road package. No upgrades other than 285/70r17 tires. I have changed the spark plugs and wires hoping it would help a little. yet there was little to no difference. Its not showing any codes. What could it be?? Oh and i'm new to Dodge Forum!!
Old Feb 15, 2013 | 03:27 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Well, if you DO have the OR package, you should have 4.10 gears in your axles, which are just fine to turn those 285's.
Check your plenum. I have a feeling that is what's wrong here.
Welcome to DF. The only place that spends your money faster than you can.
Old Feb 15, 2013 | 03:57 PM
Codynetz2001
That also has crossed my mind. But when I bought the truck 2 years ago I was told it was replaced. He had receipts and everything. But I think he just did the stock gasket. Not the Hughes performance replacement. How should I go about checking this. My mpgs are low too. Oh and thanks for the warm welcome 😳
Old Feb 15, 2013 | 04:02 PM
dodge dude94
Yeah, just because it was replaced 2 years ago doesn't mean much. If it's blown, it's blown.
You need to pull off the throttle body, get a dentists mirror or whatever, and shine a light down in there, look for oil pooling in all four corners.
Your mpgs will either be high, or in the toilet with a blown plenum. Mine were in the toilet was I was going through .5 qt per 100mi. You will also have pinging issues.
Look for the Be All End All Plenum thread at the top of this forum. That should answer most of your questions.
Old Feb 15, 2013 | 04:08 PM
Codynetz2001
Okay I'll go check it out. Thanks for all the help. I think you got me going in the right direction!
Old Feb 16, 2013 | 03:09 AM
ReadRam's Avatar
ReadRam
If the plenum gasket was blown , then your catalytic converter and 02 sensors would be toast and should've been replaced after plenum repair. A compression test would help get an idea of overall condition of motor. Bad upstream 02 will run rich and dump extra fuel. Velkommen DF.
Old Feb 17, 2013 | 02:19 AM
Codynetz2001
it only has 105000 miles on the truck. but it does use a little oil. how should I go about checking the o2?
Old Feb 17, 2013 | 08:40 AM
At 105K miles, it's time for a new one anyway.
Old Feb 17, 2013 | 09:04 AM
redneck_ram's Avatar
redneck_ram
you have an 01, you have the death flash. which would also explain the doggyness. if you want to get rid of it... contact hemifever. he can get you a tuner with 3 canned tunes for 265. mine will be here in a few days. then ill really be able to feel the difference.
when dodge_dude said this forum will spend your money faster than you can yourself.... its true. i just spent close to 4k on engine parts thanks to a few awesome members on here
Old Feb 17, 2013 | 11:08 AM
Codynetz2001
What is the death flash? I've never heard of it. What does the tuner actually correct
