97 ram 1500 trans ???
Old Feb 19, 2013 | 02:23 PM
ss/tram97's Avatar
ss/tram97
Default 97 ram 1500 trans ???
i have a 97 ram 1500 ss/t with a 5.9. It has 46re. I also have a 97 ram 1500 van with a 3.9. I'm not sure what trans is in it but my main question right now is i'm really hurting financially at least for a few more weeks so i wanted to know if i could use the van trans for my ram. At least just at least until i can afford the mega viper unit they are both 2wd and there both re units. I'm just not sure if the bolt patterns are the same any help would be greatly appreciated
Old Feb 19, 2013 | 02:30 PM
aofarrell2's Avatar
aofarrell2
well the 3.9 has a different transmission if i remember correctly. it if does itd be the 44re or 42re. ill check to be sure tho.
Posted from Dodgeforum.com App for Android
Old Feb 19, 2013 | 02:49 PM
It would probably bolt in, not sure if length is the same though.. but, unless you baby it, the 5.9 will make short work of it.....
Old Feb 19, 2013 | 03:03 PM
aofarrell2's Avatar
aofarrell2
im pretty sure the bolt pattern is different on the v6 engines. but even if it did bolt up, you wouldnt want to risk burning it up as the 3.9 has a different tranny than the 5.9
Old Feb 19, 2013 | 03:39 PM
Ham Bone's Avatar
Ham Bone
Is your 5.9l tranny completely shot?
Old Feb 19, 2013 | 08:37 PM
I think the 3.9 is just a 5.2 with two cylinders chopped off... bolt pattern should be the same.... I think.....
Should be a 42 or 44 R? Not designed to take a great deal of torque..... 5.9 would prolly kill it the second or third time you punched it.
Old Feb 20, 2013 | 08:14 AM
ss/tram97's Avatar
ss/tram97
Yea it is completely gone here's the problem I was having for the last four years I have had a whining noise from the trans it sounded like a bad hub bearing when you would let off the gas only so recently it became a grind and now it's knocking but I'm still driving for now if I turn off over drive it doesn't knock or grind but now it is starting to slip a little
Old Feb 20, 2013 | 08:19 AM
ss/tram97's Avatar
ss/tram97
Thanks for all of your help I think I am just gonna get a rent a car for a few weeks until I can afford the mega viper because I don't want it to lock up on me and at this point I don't think that it's worth double the work if the van trans wouldn't hold up for a few weeks then I would just be in the same boat and have to pull it again to put the mega viper in
