high idle
Old Feb 22, 2013 | 03:16 PM
checkersfire's Avatar
checkersfire
Default high idle
i have a 97 ram 1500 with 5.9l, just bought truck it has a high idle 1200rpm, runs great. check engine light came on noting idle sensor and o2 sensor, also #8 misfire. cleaned plug, idle sensor, codes went away but still has high idle. took off hose from breather and it has an excessive amount of vacume. plugged it off and it idles perfect????? i've heard anything from manifold, gasket to stuck valve?
Old Feb 23, 2013 | 02:37 AM
jasonw's Avatar
jasonw
Site Moderator
https://dodgeforum.com/forum/dodge-r...s-section.html
Old Feb 23, 2013 | 03:40 AM
dhvaughan's Avatar
dhvaughan
welcome to df.
replace PCV valve.
its sucking too much vac from engine and pulling it through from the breather vent you plugged.
Old Feb 23, 2013 | 11:36 AM
gdstock's Avatar
gdstock
Originally Posted by dhvaughan
welcome to df.
replace PCV valve.
Get PCV from dealer...not but about $4. After you replace that, let us know if it is fixed and if ot, we can go from there.
Old Feb 23, 2013 | 11:39 AM
My PCV from the dealer was 8 and some change.....
Old Feb 23, 2013 | 11:57 AM
gdstock's Avatar
gdstock
( they LIKE me.... )
Old Feb 23, 2013 | 11:59 AM
Whattaya sayin' there bubba?
Old Feb 25, 2013 | 03:14 AM
checkersfire
i'll try the pvc valve, it was doing this before i plugged the vent tube. after i plugged the tube, it idles perfect. i was told to pull the pvc and if it rattles, it is good, mine rattles, is there any truth to this? thanks.
Old Feb 25, 2013 | 06:59 AM
dhvaughan's Avatar
dhvaughan
rattling indicates that its not all gummed up, which generally means that its good in one direction (the ability to vent).
but according to your test where you plugged the opposite side vent, that cured your problem, which indicates your pcv is over-venting.
