Timing Cover cracked
Old Feb 25, 2013 | 09:41 AM
byronpen's Avatar
byronpen
Default Timing Cover cracked
Ok i have a cracked timing cover. Im about 70 percent sure. a while back my motor poped the radiator and over heated. then ive had a steady leak that keeps ending up in my oil pan. I used a stop leak to patch it at the moment. and now that i have a starting problem fix. Im willing to fix this now.
What should I all get and replace. when doing this?
And if anyone have a extra timing cover , Get with me.
Old Feb 25, 2013 | 09:47 AM
Adobedude's Avatar
Adobedude
Anti Freeze + engine bearings = new motor. Fix it ASAP.
Old Feb 25, 2013 | 09:54 AM
Change the timing chain and gears while you are in there.
Are you sure it's the timing cover that is leaking???
Old Feb 25, 2013 | 10:05 AM
byronpen's Avatar
byronpen
Ive inspected the heads, and i sure they are not cracked, I had a old drango a few years pack. and it had this problem. we will no for sure when it heats up a little more.
Old Feb 25, 2013 | 10:11 AM
gdstock's Avatar
gdstock
If you are going to do it that way, then you will have to do the following:
Shut it down and pull it part. +1 on timing set, new water pump, tstat, whatever else is not ne in that area. Driving it ad kknowingly allowing oil and coolant to mix is not smart. You are only making things much worse for yourself.
How did you inspect the heads?
Old Feb 25, 2013 | 10:14 AM
byronpen's Avatar
byronpen
Lets make this clear. the truck has not been driven. Ive have a starting problem and its been sitting, since the leak started. fixed starting isse and this is next on the block. this truck has been lucky if it received 1000 miles a year, when it was running good.
Old Feb 25, 2013 | 10:19 AM
gdstock's Avatar
gdstock
Ok i have a cracked timing cover. Im about 70 percent sure. a while back my motor poped the radiator and over heated. then ive had a steady leak that keeps ending up in my oil pan. I used a stop leak to patch it at the moment. and now that i have a starting problem fix. Im willing to fix this now......
That's better! The way I was reading it appeared that you were driving it.
What about the heads? You stated that you have checked them. How did you do this?
Also, check HERE.
May want to get a radiator tester (the one you pressure up) and see if you can locate where this is coming from.
byronpen's Avatar
byronpen
Did a pressure test with the radiator, didnt received any steam out of the spark plug hole. Pressure was at 12 psi. and cranked motor. no water coming out.
Old Feb 25, 2013 | 10:21 AM
byronpen's Avatar
byronpen
THat link you posted is for a 96. my truck in a 99. the ones i keep pull up are 100 plus dollars
Old Feb 25, 2013 | 10:27 AM
gdstock's Avatar
gdstock
Yep, I did not specify year when I pulled that up, so make sure you get the correct one if you order. I don't know if it is actually any different or not.
Sometimes the timing cover will leak at the water passage due to not being bolted tight enough. May want to pull Wp and then timing cover to check it. It should not crack for no reason, as there is not extreme pressure or force on these things.
