oil light situation
Old 02-27-2013, 12:09 AM
89eltigre's Avatar
89eltigre
89eltigre is offline
Default oil light situation
ok ! so last summer i had the oil light flashing when coming to an idle after driving ( especially after towing ) , so i read on here about changing to synthetic oil and putting in a cooler thermostat . did . fine till 2 wks ago i towed in a explorer with a heavy drag , and plus this winter finds the cabin temp too cool for my liking , so i switched the thermostat out to the higher temp .. lots of cabin heat now .. and no towing involved the oil light is flashing when coming to an idle again ,, now keep in mind the pressure guage has not moved last year nor this time occuring ,, so how to fix is the question ???
Old 02-27-2013, 12:20 AM
gdstock's Avatar
gdstock
gdstock is offline
Pull sender and plug in a mechanical gauge to see exactly what is going on,
Old 02-27-2013, 12:33 AM
mastermk2's Avatar
mastermk2
mastermk2 is offline
Most likely cause, oil sending unit or sending unit leaking oil into connector. If oil is in connector, replace both the sender and connector.
Old 02-27-2013, 04:10 PM
89eltigre's Avatar
89eltigre
Default oil light
gdstock ~~ would this show any more than the gauge in the dash panel ??
Old 02-27-2013, 04:12 PM
89eltigre's Avatar
89eltigre
Default oil light
mastermk2 ~~ would this not happen steady no matter what ???
Old 02-27-2013, 04:15 PM
89eltigre's Avatar
89eltigre
Default oil light
perhaps a mention ~~ when this happens a slight ( ever so ) pressure on the throttle , light goes out .. or placing in neutral .. ??
Old 02-27-2013, 05:55 PM
gdstock's Avatar
gdstock
gdstock is offline
Installing a mechanical gauge (temporarily) will help identify if it is an oil pump issue, or sender/gauge issue. It will prevent throwing parts at it and hoping to fix it.
Old 02-27-2013, 08:49 PM
Scooter78's Avatar
Scooter78
Scooter78 is offline
Im guessing your oil pressure gauge sending unit is old and a little gummed up. I would throw a new one on it, just because they are cheap and I consider them disposable. As far as I know there is no way to test the sending unit itself. Im sure someone speak up, if they know of a way. I do know that your gauge likes to see between 24.5 and 65 ohms to put the needle in the "normal range." The sending unit uses a diaphram to change the resistance it puts out, thus giving you a variable reading.
Old 02-27-2013, 08:51 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,276 Likes on 3,023 Posts
I remember, back in the day, when auto manufacturers could make an oil pressure sending unit that would last longer than the engine it was screwed into..... Unlike the units you see today, that simply doing an oil change can trash 'em...... Yes, I am looking at YOU Generous Motors....... Dodge apparently gets theirs from the same place.
Old 02-27-2013, 09:34 PM
89eltigre's Avatar
89eltigre
Default oil light
~~~~~ i guess i'm too detailed oriented , sorry ,, will a gauge attached at the sender unit tell more than the needle gauge in the dash ?
Quick Reply: oil light situation
