Misfire Woes
Old Feb 28, 2013 | 10:33 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Originally Posted by moe7404
i have found that dodge trucks with a disturber next to the fire wall tend to collect moistener in the cap. it has a vent hole that should plugged with JB-weld. it took me 5 years to figure that out. how ever if some systems run vacuum through the cap dont plug them.
Mine isn't plugged and it runs great.
Old Feb 28, 2013 | 10:42 AM
Reason there is a vent hole there is so various gases coming up from the crankcase, via the distributor shaft, have a place to go. I have seen unvented caps that trapped combustibles in them, literally explode, as there seems to be a rather frequent ignition source there...... Of course, if it ISN'T vented, you would think you would have less gas intrusion there. Not sure if that translates to less oil getting up there as well.... I haven't seen a distributor fail due to lack of lubrication, unless the WHOLE ENGINE followed on shortly thereafter.
