front axal u-joint
Old Mar 1, 2013 | 02:57 PM
bunker's Avatar
bunker
Default front axal u-joint
can anybody tell me what size is the axial nut or castle nut is on the front axial?
I have seen videos about how to change the right/passenger side but not the left/dvrs side. can someone tell me if its the same??
Old Mar 1, 2013 | 03:11 PM
kejobe's Avatar
kejobe
The process is the same for either side. Just one axle is longer. The nut is 1 11/16".
Old Mar 1, 2013 | 08:50 PM
dhvaughan's Avatar
dhvaughan
94-01 4wd is 1-11/16. most chain type parts stores don't carry it. you can get an expensive one at napa or a cheap one at harbor freight or tractor supply.
2000-2001 2wd might???? be 1-3/8
Old Mar 2, 2013 | 11:06 AM
bunker's Avatar
bunker
Default great
thanks all that sounds like a 45mm to me thats what i have dont have any american size sockets that big.
time to go to work
Old Mar 2, 2013 | 11:23 AM
Blackbox19's Avatar
Blackbox19
Do you have to take that nut off? Or can you just pull the hub and all and replace the u joint? I use to do this with my Jeeps and they have exactly same set up, just a little smaller.
Saves not having to buy that big socket
Old Mar 2, 2013 | 12:52 PM
Sure, makes it a little more interesting, but, if you can work around it, don't absolutely have to pull the axle out of the hub.
Old Mar 2, 2013 | 01:53 PM
merc225hp's Avatar
merc225hp
That's how I do mine, I think it's ezer but that's me.
Old Mar 3, 2013 | 09:33 AM
bunker's Avatar
bunker
Default not sure
all i have to go on is a few videos ive seen on yt about pulling it off. getting ready to try it in a few hours once it warms up.
Old Mar 3, 2013 | 10:01 AM
zman17's Avatar
zman17
Retired Moderator - RIP
The hub bearing is eventually going to go bad more likely than not, so you might as well get the socket. Only problem is, that you'll need a torque wrench capable of 180 foot pounds to reinstall it. Which you'll need a torque wrench capable of at least 125 to reinstall the hub assembly bolts anyway.
Old Mar 3, 2013 | 10:29 AM
Blackbox19's Avatar
Blackbox19
Is there C clips in the diff on these axles? Sorry I know I am Hi Jacking, but this applies to his post and if he did not know about this, now he does. OR SHE...
I have a well equipped shop, but those that dont, and they just need to replace that U joint.
