another 2nd gen tranny thread
Old Mar 6, 2013 | 11:01 AM
northamerican's Avatar
northamerican
Default another 2nd gen tranny thread
Last night I pulled a guy out of a sno bank, fairly effortlessly with my 99 ram 2500, 360ci gas 4x4. After that my truck wouldnt shift out of first gear, This morning I topped up the fluid (1L) and dumped a quater can of seafoam in the tranny than went for a ride, It is shifting and driving flawlesly. No problems at all. The tranny is a rebuilt one with 20,000 kms on it, so its fairly fresh. Any Idea what would have caused this, will it happen agin. What should I do.
Old Mar 6, 2013 | 11:09 AM
Low fluid level might have done it. Got any leaks?
Old Mar 6, 2013 | 11:10 AM
zman17's Avatar
zman17
Retired Moderator - RIP
I suggest you do a fluid(atf+4) and filter change soon and get as much of that crap out of the tranny as possible. While the pan is off, check the governor solenoid and clean it. Add a drain plug to the pan also.
Old Mar 6, 2013 | 11:29 AM
northamerican
no leaks, ill do fluid change this weekend
Old Mar 13, 2013 | 08:29 AM
northamerican
happened again last night, and this mornig it drives like a new truck again, tell me more about the govener solinoid, or anything else you can think of, could it be electrical?
Old Mar 13, 2013 | 08:49 AM
zach01's Avatar
zach01
does it have a warrenty? if so id just sit there holding the brakes and getting it some gas..(not burning out tho) and heat up the convertor till the tranny lets go... that how i get the one replaced in my truck. had the same problem and it was still under warrenty so i fried it and they put a new one in
Old Mar 13, 2013 | 09:05 AM
northamerican
does anyone have a pressure sensor and solonoid OEM part number, or a link to where I can buy one.
Old Mar 13, 2013 | 10:44 AM
Ebay, from seller ElectricalAdvantage. Borg Warner governor pressure solenoid, and OEM sensor.
Old Mar 13, 2013 | 11:12 AM
northamerican
this one
http://www.ebay.com/itm/HEAVY-DUTY-G...63fff4&vxp=mtr
Old Mar 13, 2013 | 11:13 AM
northamerican
or this one
http://www.ebay.com/itm/DODGE-JEEP-4...c60877&vxp=mtr
