Misfire number 8 after plenum fix
Old Mar 8, 2013 | 11:54 PM
  #31
ReadRam's Avatar
ReadRam
If you unplugged the no 8 injector and didn't notice any changes you have an issue with that injector.
Not necessarily, could still be missing for other reasons.
Old Mar 9, 2013 | 01:35 AM
  #32
RamIt4792's Avatar
RamIt4792
Originally Posted by gdstock
Dry, wet, leakdown? Did you check injector pulse?
I think its dry idk the one where you take out the injector and put in the hose and crank the engine a couple times
Old Mar 9, 2013 | 02:10 AM
  #33
gdstock's Avatar
gdstock
Compression test is done by removing spark plug and connecting...not the injector.
Check for injector pulse. No pulse, it will not open.
Old Mar 9, 2013 | 10:47 AM
  #34
RamIt4792's Avatar
RamIt4792
Sorry thats what i meant the spark plug not the injector lol. but ill check for pulse when I get back to my job Tuesday, just hope someone has a noid light
Old Mar 9, 2013 | 11:13 AM
  #35
zman17's Avatar
zman17
Retired Moderator - RIP
You can back probe the injector plug with a DVM also.
Old Mar 9, 2013 | 08:54 PM
  #36
RamIt4792's Avatar
RamIt4792
What is a DVM?
Old Mar 9, 2013 | 09:00 PM
  #37
gdstock's Avatar
gdstock
Digital volt meter.
Old Mar 11, 2013 | 01:23 AM
  #38
RamIt4792's Avatar
RamIt4792
Okay guys ive done every test possible injectors are fine, plugs, wires, cap, rotor, connections are good, compression. But still shows a misfire on the computer... no code tho. I give up! I think its just a pcm issue? idk but im done monkeying with it she drives beautiful and just took it off roading the other day with no issues
Old Mar 11, 2013 | 06:02 AM
  #39
zman17's Avatar
zman17
Just keep using the Techron for now.
Old Mar 11, 2013 | 09:52 PM
  #40
RamIt4792's Avatar
RamIt4792
Okay guys found the issue, driving down the road and the welded seal around the catalytic converter came apart and started leaking like crazy. Truck started to run and drive like crap I had to baby it home. So do I have to have it welded in or can I use clamps? Thanks for all the help too btw. Love these forums!
