Timing cover Bolt/sockett size
Old Mar 7, 2013 | 01:21 PM
byronpen's Avatar
byronpen
Default Timing cover Bolt/sockett size
The bolt that runs dead center on the pulley on the bottom of the motor that shows top dead center. what Size is it.
Old Mar 7, 2013 | 01:42 PM
zman17's Avatar
zman17
Retired Moderator - RIP
1 1/4" I believe.
Old Mar 7, 2013 | 02:14 PM
byronpen's Avatar
byronpen
Best way to remove fan clutch. With out spending 50 dollars on a once use tool
Old Mar 7, 2013 | 02:26 PM
zman17's Avatar
zman17
Rent one from your local FLAPS. Do you have a large enough adjustable wrench to fit the fan clutch nut?
Old Mar 7, 2013 | 06:48 PM
byronpen's Avatar
byronpen
Yep I have A tool boxed filled from my days in the army.
What dose that run as a rental.?
Old Mar 8, 2013 | 06:29 AM
zman17's Avatar
zman17
I have no clue how much to rent. But if you have an adjustable for the nut, You can wedge a screwdriver across the smaller nuts to hold it.
Old Mar 8, 2013 | 07:18 AM
aim4squirrels's Avatar
aim4squirrels
38mm is the fan clutch, iirc.
Old Mar 8, 2013 | 07:44 AM
redneck_ram's Avatar
redneck_ram
36mm, actually.
Old Mar 8, 2013 | 08:55 AM
I put a big adjustable wrench on it, left the serp belt on, and SMACKED the wrench with a hammer to break it loose. Then it unthreaded by hand.
Old Mar 8, 2013 | 09:46 AM
Arde's Avatar
Arde
15" crescent, my 12" didn't quite make it.
