Loss of Brake Power/ Mist in vents/ Loss of fluid
Thanks for the suggustions. I will be removing the Master Cylinder from the Vacuum booster and checking that after work today. As for thinking i have two separate problems, i don't know if i want to go that route, they both seemed to happen at the same exact time.. Thanks!
I ask, because you're basing your conclusion on a causation versus correlation fallacy.
I'm a 17 year old "kid" who has been trained in the basics. That being brakes, suspension and basic engine components. I enjoy working on my own truck and learning how it works, it makes me feel good that I'm able to do it. And if belittling me makes you feel good you go right ahead. As for everyone else, I appreciate the help. I just replaced the heater core myself in under 4 hours(which id say is pretty good) but what do I now...
OK. Chill a little. He was referencing your immediate dismissal of the idea that two unrelated problems happened at the same time. There is no connecttion between the ac vent systems and brake system. Coincidence is possible...
Did the heater core you took out look bad? Did that fix your problem?
