mystery ticking noise from hell.
Old Mar 10, 2013 | 12:16 PM
ramrookie92's Avatar
ramrookie92
Wink mystery ticking noise from hell.
So im in the final stages of my build i just had the tranny rebuilt and i overhualed the motor this inculded new valve cover gaskets,new wires,plugs,cap/rotor,and new ignition coil. I also installed a k&n drop in highflow. Along with new injector seals new doorman plenum kit wich included new belly pan bolts new intake bolts and a set of intakerunner gaskets. I also did new radiator new thermostat and new waterpump,new timingchai new front seal and new timing cover gaskets.i have also done new 02sensor. So heres the proble..after all of that i still have a ticking noise starting at 1800 rpm and stoping at 2500.its def not knock or ping or lifter tick. What else could it be. Someone told me these motors are noisey (5.2/318) and its nothing. I have also heard its noisy injectors or a bad exhuast manifold if anyone could chime in that would be great. Also my truck has 114k on it and i use synthetic.
Old Mar 10, 2013 | 12:39 PM
Might be lifter tick if you reused the old ones. Switching back to dino oil may or may not reduce it. (if it does, you can be pretty sure it is indeed a lifter.)
Might also be one of your rockers isn't quite tight....
Could also be an exhaust leak..... or serp belt... or a bunch of other stuff.
Old Mar 10, 2013 | 12:51 PM
newman1367's Avatar
newman1367
With the work on the front, did you drop the oil pan and replace the pump?
Old Mar 10, 2013 | 01:28 PM
dhvaughan's Avatar
dhvaughan
+1 on consider an exhaust leak. especially with headers and especially if your exhaust is not welded up.
Old Mar 10, 2013 | 02:03 PM
ramrookie92
No i havent changed the oil pump and i hqvent switched back to dino but why would dino make it not tick ? And its factory manifolds no headers.
Old Mar 10, 2013 | 02:04 PM
ramrookie92
And i think ita not a rocker my mech said when he looked at my rockers under my valve covers they looked good with min wear.
Old Mar 10, 2013 | 03:00 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
I ran synthetic oil after my rebuild and not a problem. Anyone who claims these engines are "noisy" is full of bee ess.
My truck did develop a tick at idle that would go away after a few revs of the throttle. I attributed that ticking to an injector.
Old Mar 10, 2013 | 04:57 PM
ramrookie92
I feel like its a manifold leak the truck runs sooooooo smooth and clean and has no ping or hick ups at idle all the way to redline. I feel like im being over cautious. But i would like more opions plus my oil pressure is always great and it starts up veryy quick. Only think i can say is it isnt to fond of cold weather.
Old Mar 10, 2013 | 07:30 PM
ramrookie92
I want to know how syn oil is naking it tick insteas of dino. Isnt it supose to be better. It seems smoothing on syn oil. And ied like to know how hard is it to do manifolds.
Old Mar 10, 2013 | 07:51 PM
Ham Bone's Avatar
Ham Bone
Do a search
