No 3-2 downshift on 46re 2000 ram
Old Mar 10, 2013 | 05:17 PM
ReadRam's Avatar
ReadRam
Smile
Originally Posted by zman17
Key trick= Turn the engine off, then turn the key ON, OFF, ON, OFF, ON without starting the engine. Any codes will come up on the odometer.
Not on a 99, at least my doesn't. Nevermind didn't see it was 2000 and 2001 it works.
Old Mar 10, 2013 | 05:21 PM
pure adrenaline's Avatar
pure adrenaline
btw this is an awesome trick. Does it show any and all codes that would normally show up with a scanner? (eg. emission, engine, transmision, etc..)
thank you in advance
Old Mar 10, 2013 | 05:32 PM
ReadRam's Avatar
ReadRam
Originally Posted by pure adrenaline
Thanks, I'll need to look up what that involves. I thought I ran across a "how to" which seemed to be very involved. I wonder how much a transmission shop would charge to diagnose(pressure test) it?
Call around a good shop will do a free ride diagnosis, check pressures etc...
I don't really understand what you mean. If your in OD cruising 50 mph and you kick it down,, it won't downshift? But it upshifts through all the gears at moderate acceleration just fine?
Old Mar 10, 2013 | 05:41 PM
pure adrenaline
Exactly other than it does downshift from 4-3 perfectly too. It is just the 3-2 downshift that redlines. As an example at 50mph and a light acceleration it will downshift from 4-3 but with further acceleration, after the 4-3 shift, where I would expect it to go from 3-2 it goes from 3 and redlines-slips.
Last edited by pure adrenaline; Mar 10, 2013 at 05:50 PM. Reason: additional details
Old Mar 10, 2013 | 05:42 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yeah, unfortunately it doesn't work on 98's at all, and some 99's, one of them being your's.
Old Mar 10, 2013 | 07:08 PM
These transmissions are known for strange behavior at WOT...... governor pressure sensor gets saturated..... and PCM gets wrong readings. Not sure if there is a fix for it...
Old Mar 10, 2013 | 07:15 PM
stewie01's Avatar
stewie01
MegaViper?!
Old Mar 10, 2013 | 07:16 PM
Originally Posted by stewie01
MegaViper?!
That would prolly work.
Old Mar 10, 2013 | 07:58 PM
zman17's Avatar
zman17
This may also help. http://dnjcomponents.com/index.php
Old Mar 10, 2013 | 08:17 PM
stewie01's Avatar
stewie01
Fancy smancy governor solenoid assembly thingy?
