No 3-2 downshift on 46re 2000 ram
Old Mar 10, 2013 | 04:06 PM
pure adrenaline's Avatar
pure adrenaline
Default No 3-2 downshift on 46re 2000 ram
I have been reading and searching for a couple days but cannot find a straight answer for my problem. Everything else seems to be shifting perfectly except when I go WOT at any speed where I am in OD or 3rd(od off). The transmission goes into neutral and the rpm's redline. It shifts fine from 4-3 with light acceleration but at WOT the 3-2 downshift is not occuring.
Any help on what part or parts might be causing this would be greatly appreciated. I have already adjusted\re-adjusted the TV cable all over it's range with the 3-2 still occuring.
Old Mar 10, 2013 | 04:22 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Have you tried checking for codes? (key trick) And check this out from the FAQ/DIY section. https://dodgeforum.com/forum/2nd-gen...agnostics.html
Old Mar 10, 2013 | 04:37 PM
pure adrenaline
I have read that and the closest failure description was "NO KICKDOWN OR NORMAL DOWNSHIFT". Short of buying all the diagnostics equipment and hours of troubleshooting needed, I was really hoping since I intended to replace the governer sensor and the filter I could bypass all the troubleshooting and just pre-purchase the most likely failed part(s). From what I have read so far most likely my problem is in the valve body but if I could pre-order any cheap, hard to find parts which are likely causing the issue I might could get the job done in a day.
I do have a basic scanner but I don't think that is what is needed for pulling codes from the transmission. No codes were found otherwise. What is the "key trick"?
Thank you for your response.
Old Mar 10, 2013 | 04:45 PM
zman17's Avatar
zman17
Key trick= Turn the engine off, then turn the key ON, OFF, ON, OFF, ON without starting the engine. Any codes will come up on the odometer.
Old Mar 10, 2013 | 04:49 PM
gdstock's Avatar
gdstock
TV cable "adjusted\re-adjusted the cable all over it's range?" There is one correct setting... Start there.
Old Mar 10, 2013 | 04:55 PM
zman17's Avatar
zman17
The starting point can be found in this thread. https://dodgeforum.com/forum/2nd-gen...-in-trans.html
And if you want to screw around with it afterwards. http://www.bionicdodge.com/Download/...Adjustment.pdf
Old Mar 10, 2013 | 04:58 PM
pure adrenaline
Thanks I just tried that and it displayed "p done" I think it means no codes.?
Old Mar 10, 2013 | 05:01 PM
pure adrenaline
That is what I meant by "all over it's range". It does not fix the downshift problem with it correctly set or in any other position.
Old Mar 10, 2013 | 05:04 PM
zman17's Avatar
zman17
I know you want to fix it cheap, but it simply needs to be pressure checked.
Old Mar 10, 2013 | 05:09 PM
pure adrenaline
Thanks, I'll need to look up what that involves. I thought I ran across a "how to" which seemed to be very involved. I wonder how much a transmission shop would charge to diagnose(pressure test) it?
