Lack of Power, ????
Old Mar 12, 2013 | 11:33 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
That could be part of it.
These trucks HATE Bosch.
Old Mar 12, 2013 | 11:34 AM
merc225hp's Avatar
merc225hp
Originally Posted by Arborist87
well, to be honest, it is a bosch O2 sensor.
And now you will be told to put in a NTK 02 sensor, and it won't make a difference. Was the dizy removed or moved when this work was done?
Old Mar 12, 2013 | 11:48 AM
Arborist87's Avatar
Arborist87
Nope, I made sure not to remove or alter the distributor in any way shape or form. Do you think maybe the timing chain has stretched and needs replaced?
Old Mar 12, 2013 | 11:50 AM
dodge dude94
Stretched timing chain wouldn't have much affect on it. Or at least not to that degree.
Old Mar 12, 2013 | 01:17 PM
zman17's Avatar
zman17
Retired Moderator - RIP
As stated, got to fix the bad gasket first. I'm wondering if the other intake gasket(s) are not screwed up too. Did you use new bolts for the intake ? If so cut the head off a couple of the old ones and screw them in some to use as guides to seat the intake. And I see no mention of anything being done about the lower intake gasket and plate? (other than you rebuilt the top end).
Old Mar 12, 2013 | 01:42 PM
Arborist87's Avatar
Arborist87
I did change the plenum gasket with a felpro one. I did not use new bolts for the intake manifold but when I take it back off (tomorrow) I will buy new hardware to use. Since the gaskets have only been on for a day can I re-use them or should I just get new ones?
Old Mar 12, 2013 | 02:19 PM
zman17's Avatar
zman17
New!!!! Lol Just so you know(if you don't already), on the front and rear rubber gaskets there are little **** for the lack of a better word. You need to clean out the holes on top of the block so they will fit into said holes.
Old Mar 12, 2013 | 03:57 PM
Doing the timing chain NOTICEABLY boosted power on my truck. Of course, it had 169K on it when I changed it out..... and was stretched out pretty bad.
I would be tempted to have fuel sync checked, just to eliminate it as a possibility.
How's your compression? (run a test. )
Old Mar 12, 2013 | 05:01 PM
Arborist87's Avatar
Arborist87
Are you trying to imply something?
Old Mar 12, 2013 | 07:51 PM
Arborist87's Avatar
Arborist87
I just remembered, my BRAKE light and ABS light are illuminated on the dash.
Can this possibly be a tranny problem?
