ECM question
Old Mar 12, 2013 | 09:24 AM
windfreak0's Avatar
windfreak0
Default ECM question
Bought a 1997 Ram 3500 van at auction. 5.2 L motor. No spark from coil. Measured voltage across two wires to coil (result: 2 V with ig on). Replaced ECM. Same condition. Replaced crank position sensor. Same. Replaced pickup in distributor (camshaft sensor?): same. Swapped out ASD relay: same. I have a replacement ignition switch coming (I read that these commonly go bad). Anyone have experience with bad ig switches on these vehicles?
Question: could a bad fuel pump cause the ECM to not generate a spark signal to the coil? I thought I read about that somewhere.
Old Mar 12, 2013 | 12:29 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The coil only gets power for a few seconds at a time. So you have to check it with 2 people. One at the meter, and one to turn the key on.
Old Mar 12, 2013 | 12:47 PM
windfreak0's Avatar
windfreak0
Default meter viewing.
I did just that. I am able to have a meter in the cab while turning the key. It basically is at 2 V while cranking (might drop to 1.8-1.9) but is essentially constant.
One of the nice things about a van (you're basically under the 'hood').
Old Mar 12, 2013 | 12:48 PM
windfreak0's Avatar
windfreak0
Default also the rotor turns...
which means I don't have a broken timing chain.
Old Mar 12, 2013 | 01:29 PM
zman17's Avatar
zman17
Oh yea, forgot about the van factor. And yes, IIRC , if you have no fuel pressure the ASD will shut down. So you need to check that pressure with a gauge.
Old Mar 12, 2013 | 01:48 PM
windfreak0's Avatar
windfreak0
Default fuel pump
Thanks Zman. I haven't checked, but I've read folks depressing a Schrader valve to see if fuel pressure is there while cranking. Know where that might be located on this rig? I haven't looked yet to see where the fuel pump might be located. Is it at the tank or up near the engine?
Cheers,
Windfreak
Old Mar 12, 2013 | 02:26 PM
zman17's Avatar
zman17
Damn man, you have a 97(bummer). If it's anything like a ram pickup you have a plastic fuel rail and there is no test port. You need a gauge and a special adapter to check pressure.
Old Mar 12, 2013 | 02:46 PM
windfreak0's Avatar
windfreak0
Default fuel gauge
Something like this?
http://www.harborfreight.com/catalog...pressure+gauge
If so, I can spring for $20.
Old Mar 12, 2013 | 03:07 PM
windfreak0's Avatar
windfreak0
Default fuel pump question
Is the fuel pump on top of the fuel tank on this van? If bad, you have to remove it right, as opposed to putting a new one in the fuel line and leaving the old one in place?
Old Mar 12, 2013 | 03:30 PM
zman17's Avatar
zman17
That kit will get you started, but you'll need one of these if you indeed have a plastic fuel rail. http://www.mytoolsforyou.com/automot...STR-74484.html
