Quick ujoint question
Old Mar 12, 2013 | 08:24 PM
kcchief's Avatar
kcchief
Default Quick ujoint question
The front left drivers side ujoint has been clicking for a while. I finally figured out what was clicking with some help from some people on here. I was going to take it tomorrow to have it fixed. Today on my way home it started a really louder clunk with a whine and then my truck started slowing down. I pulled over to the side of the road and when I would try to go forward or backwards it didnt want to unless I gave it some gas. When the ujoint has finally had enough is this what it does? I am hoping it is not something else as well......
Old Mar 12, 2013 | 08:40 PM
dhvaughan's Avatar
dhvaughan
i think you need to stop driving it immediately. at least until you prove that your not about to explode the yoke. if you blow the yoke, you're looking at potentially expensive damage.
check its looseness. has it changed? is it minor play, or major?
tylerhodgson699's Avatar
tylerhodgson699
Chances are the u joint is broke and its getting bound up between your inner and outter axle shafts. Dont drive it anymore! You will end up taking out the ends of your axle shafts if you havnt already. You'll probably need a wheel bearing too if you havnt recently replaced it already because they are not fun to get out!
Old Mar 12, 2013 | 08:48 PM
kcchief's Avatar
kcchief
Not driving it, had a tow truck come get it on the side of the road and now it is sitting down at the repair shop for them to fix tomorrow.......
Old Mar 13, 2013 | 06:27 PM
kcchief's Avatar
kcchief
Ok the bad news, both ujoints on the front have to be replaced, they where binding up.
Good news nothing else was affected by it so it did not cause more damage.
Old Mar 14, 2013 | 08:29 PM
dhvaughan's Avatar
dhvaughan
just out of curiosity, how much does it cost to replace both u-joints? parts and labor.
Old Mar 16, 2013 | 11:06 AM
newman1367's Avatar
newman1367
Long and hilarious story short, I was quoted over $300!! And that was 10 years ago.
Old Mar 22, 2013 | 06:25 PM
shoe3155's Avatar
shoe3155
I tried to limp my truck into town on a completely blown u joint and broke the yoke on the axle shaft. All said and done was about $700 you made the right call
