1997 Dodge Ram 2500 wont move(auto 5.9).
Old Mar 13, 2013 | 02:30 PM
zeus53219's Avatar
zeus53219
Default 1997 Dodge Ram 2500 wont move(auto 5.9).
Driving home the truck made a loud clunk. Being less then a block from my home I processed to drive it, it made several loud clunking noises and lunged. I parked it now it wont move at all. Tried 2wd and 4wd fwd and rev with no success. Any suggestions where to start would be greatly appreciated?
Old Mar 15, 2013 | 09:05 PM
jasonw's Avatar
jasonw
Site Moderator
https://dodgeforum.com/forum/dodge-r...s-section.html
Old Mar 15, 2013 | 09:19 PM
stewie01's Avatar
stewie01
Those tires look huge, what gear ratio you running?
Old Mar 15, 2013 | 09:22 PM
dlyter09's Avatar
dlyter09
Checked the transmission fluid? Your driveshafts still there?? Kind of a weak description of things.. Have you checked anything at all? My guess would be your trans has decided to go boom...
Old Mar 16, 2013 | 07:04 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Or transfer case.
Old Mar 16, 2013 | 08:28 AM
guzman's Avatar
guzman
As high as that truck sets you should be able to slide on a creeper and visually check everything under the truck for a problem, do some feeling around and twisting some u-joints etc., block the wheels and put truck in nuetral. If nothing start by jacking up the front end and turning the wheels then do the same on the rear=process of elimination.
Old Mar 18, 2013 | 08:22 AM
zeus53219's Avatar
zeus53219
Pulled back diff cover, ring gear is tooth-less, lots of metal laying in the bottom. Truck is dead in the water for a while.
Old Mar 18, 2013 | 08:42 AM
stewie01's Avatar
stewie01
What gear ratio were you running?
Old Mar 18, 2013 | 03:37 PM
zman17's Avatar
zman17
Put it in 4wd, at least you'll be able to go to the store for beer.
Old Mar 19, 2013 | 07:07 AM
zeus53219's Avatar
zeus53219
She's locked up pretty good.
