intake bolt broke off in head! need help asap
I am doing the plenum and all the bolts came out except for the front passenger side. it is fused and looks like its welded to the head. it snapped off and there is just a tiny bit sticking up. tried pb blaster and heat and couldnt get it. Ive never used a bolt extractor. I need my truck back together very soon. I need help on what to do. here is a pic. and does anyone know what size bolts they are?Attachment 19221
More penetrating oil and more heat. Looks like enough is sticking out to get visegrips on it . Turn it in(as in tighten) and out. If you can turn it in a little use a 1/4 " angle die grinder to clean the under side of the threads. All I can say is keep tightening and loosening once it moves in the slightest bit.
start by covering up the intake port with duct tape...
clean all that rust/grime surrounding the stud with a wire brush , then try more pb blast and heat... tap lightly with a hammer both the stud and the surface area surrounding it and make sure your visegrip has a good amount of ''bite'' left in its jaws
Trending Topics
