8th Cylinder Misfire
Old Mar 21, 2013 | 09:22 PM
ThaBigYoss's Avatar
ThaBigYoss
Default 8th Cylinder Misfire
I have a 2001 Ram 1500 5.9L Sport and about a week ago I had my check engine light come on. I ran the code and it was an 8th cylinder misfire (don't remember the number on it). I checked my engine and saw that the wire connecting the spark plug to the distributor wasn't plugged in to the distributor, so I plugged it in and cleared the code. I kept driving it and about 30 miles after clearing the code the light came back on. All my wires are good as far as I can see so not sure if that's the problem although I'll probably replace them and the plugs anyway. I also have noticed my truck has no power lately and it sounds less powerful through my exhaust. I did step on it today and my light actually turned off until I let off the gas. Anyone have any ideas what's wrong?
Old Mar 21, 2013 | 09:31 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
How many miles?
Read this thread: https://dodgeforum.com/forum/2nd-gen...um-thread.html
Old Mar 21, 2013 | 09:35 PM
ThaBigYoss's Avatar
ThaBigYoss
I just went over 127k
Old Mar 21, 2013 | 09:46 PM
redneck_ram's Avatar
redneck_ram
fix the plenum replace the cat, its beginning to clog.
Old Mar 21, 2013 | 10:01 PM
ThaBigYoss's Avatar
ThaBigYoss
I read something that said going to an aftermarket, thicker pan, on the plenum would make it not burn up again and to possibly install a new intake. Would either of these make any difference.
Old Mar 21, 2013 | 10:19 PM
Johnn123's Avatar
Johnn123
Read the link WK posted will tell you everything!
Old Mar 21, 2013 | 10:32 PM
ThaBigYoss's Avatar
ThaBigYoss
Somehow I didn't even see that link...
Definitely helps a lot.
Old Mar 21, 2013 | 11:29 PM
merc225hp's Avatar
merc225hp
So the plug wire was off of #8, so for how ever long that cyld was not firing it was being washed down with fuel, not good. Do a comp test to see what is going on with the motor.
