Help with power steering
Old Mar 23, 2013 | 12:35 PM
95 dakota sport's Avatar
95 dakota sport
Default Help with power steering
I just sold my Dakota an bought a 98 ram 1500 wit a 5.9 in it and it keep ripping the belt up on one side of it. It looks like the power steering pump pulley is sticking out a little more than the other pulleys
Old Mar 23, 2013 | 01:01 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You need to check the alignment of all the pulleys obviously. Also check the amount of ribs in each one and make sure the belt ribs matches that amount.
Old Mar 23, 2013 | 03:11 PM
95 dakota sport
The belt and the pulleys have the same amount of ribs the power steering pump pulley Is sticking out about one rib fether than rest of the pulleys
Old Mar 23, 2013 | 03:15 PM
gdstock's Avatar
gdstock
See if pump bracket is loose, allowing for the misalignment.
Old Mar 23, 2013 | 03:17 PM
zman17's Avatar
zman17
And make sure the belt tensioner is working properly and has full travel.
Old Mar 23, 2013 | 03:31 PM
95 dakota sport
The tensioner has full travel and the bracket is tight by chance does anyone no wat the space is in between the pump and the bracket
Old Mar 23, 2013 | 07:25 PM
95 dakota sport
Is there sup to have play in the power steering pump?
Old Mar 23, 2013 | 07:37 PM
gdstock's Avatar
gdstock
No. What kind of play?
Old Mar 24, 2013 | 08:47 AM
95 dakota sport
U can move the power steering pump shaft the one wit the pull on it about 8th of an inch or little less then that
Old Mar 24, 2013 | 09:16 AM
Pump is bad. Time for a new one.
