Broken Timing chain / need help
Old Mar 26, 2013 | 10:36 PM
gdstock's Avatar
gdstock
OK. Great that you don't think it has the problem. But I would check anyway. It is obvious form your description that something is wrong!
Old Mar 26, 2013 | 11:04 PM
xrockfury's Avatar
xrockfury
True. Ill check it. Ill do the pressure check as well..
Old Mar 26, 2013 | 11:18 PM
gdstock's Avatar
gdstock
At least if you check and it is not blown, we can think of another possibility.
Old Mar 27, 2013 | 10:31 AM
Compression test first....... I am not completely convinced these are 'spin-free' motors.
Old Mar 27, 2013 | 04:28 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The pistons should not hit the valves if the chain breaks on a magnum motor. Maybe when it happens at a high rpm the compression at that moment can bend valves or something, who knows. I'd do the tests these guys have suggested and go from there.
