Add. hoses cooler / expansion tank
Old 04-17-2013, 11:30 AM
gdstock's Avatar
gdstock
gdstock is offline
Just unscrew them, and then cap 'em off. Shouldn't get any coolant out of them.
Someone bypassed it. If it would leak, it would be doing it now! What about the lower fitting? Is it cut off also?
Old 04-17-2013, 03:45 PM
ZipZap's Avatar
ZipZap
ZipZap is offline
Yep. Both ends cut off and bypassed to a retrofit rad. So the remainder of the tube should be dry... I was unsure if eliminating the old connections at the main radiator will cause any issues though.
Old 04-17-2013, 04:12 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
The only issue that can come up, is if it's real cold out, the truck might not want to shift to OD right away if the tranny is not up to operating temp.
Quick Reply: Add. hoses cooler / expansion tank
