trans help please!!!
Old Mar 30, 2013 | 10:05 PM
dnxracer's Avatar
dnxracer
Default trans help please!!!
Ok I got a 96 ram 2500 2wd off of my boss wouldn't go into gear he thought trans was out but was clogged filter I changed filter and fluid only slips in first shifts fine goes,down road fine at 60 mph rpms stay at 2 grand I've adjusted both bands and still slips only if u try to floor it if u drive it normal no skip in first o yea there was melted shavings on magnet and in pan does that mean i need to change low gear band any help is appreciated o yea don't slip in reverse either
Old Mar 30, 2013 | 10:15 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If you want help, instead of grief, from the very knowledgeable people here. I suggest you add some punctuation to your post.
Old Mar 30, 2013 | 10:43 PM
kejobe's Avatar
kejobe
punctuationhuhwhatisthat??
Old Mar 30, 2013 | 10:52 PM
zman17's Avatar
zman17
See what I mean, dnxracer ? Don't get all upset either, we are kind of lax around here, so just roll with it.
Old Mar 30, 2013 | 11:42 PM
gdstock's Avatar
gdstock
Check fluid level, in neutral, with tranny warmed up. Make sure it is full.
How much stuff was on the magnet?
How did you adjust the bands?
What kind of fluid did you use?
Old Mar 31, 2013 | 07:24 AM
dnxracer's Avatar
dnxracer
I loostened nut 4 turns tightened to 72 in pounds then loostened adjuster however much they called for an the magnet was covered and I used dextron 2 is Wat my dipstick calls for
Old Mar 31, 2013 | 09:13 AM
guzman's Avatar
guzman
Default Fluid
ATF +4 is the desired Trans. fluid if you decide to change it out again.
Old Mar 31, 2013 | 09:49 AM
Dex 2 will not allow your trans to work properly. Need to change fluid to ATF +4.
Old Mar 31, 2013 | 09:54 AM
zman17's Avatar
zman17
I guess I was ignored. LOL
Old Mar 31, 2013 | 10:09 AM
dnxracer's Avatar
dnxracer
It says on my dipstick to use that dextron y don't it Wrk
