ABS and BRAKE light on
Old Mar 31, 2013 | 03:56 AM
zach01's Avatar
zach01
Default ABS and BRAKE light on
i got a 01 dodge ram 2500 4x4 with 4 wheel ABS and for about a year my ABS light and BRAKE lights are constently on. and ive checked out all the connections for the abs where them come out of the hubs and i even replaced both front hubs to see if that was the problem but no luck... before i take it to a shop and spend to much money are there are other things i can look at and that i could do myself.... also my brakes luck up not so i know the ABS isnt working
Old Mar 31, 2013 | 09:48 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You can try replacing the sensor on top of the rear diff. Also check the brake line that runs by the gas tank. It can have a very small pinhole. Also, do the key trick and see what if any codes come up. https://dodgeforum.com/forum/2nd-gen...code-list.html
Old Mar 31, 2013 | 09:50 AM
ABS codes won't come up with the key trick. Need a scanner to read 'em. I don't think parts store scanner will do ABS either....
Old Mar 31, 2013 | 10:04 AM
zman17's Avatar
zman17
If the rear sensor is bad it should come up. Did on mine.
Old Mar 31, 2013 | 10:27 AM
That's new.
You got 4wal? or Rwal on yours?
Old Mar 31, 2013 | 10:33 AM
zman17's Avatar
zman17
Rear only on mine, Op says he replaced front hubs, so I'm thinking the rear sensor. I'm wondering if resetting the pcm will do anything. Worth a shot anyway.
Old Mar 31, 2013 | 10:35 AM
I never had much success resetting ABS codes that way.... but, my experience is mostly with GM systems....... you HAD to use a scan tool to clear abs codes on those. It was.... annoying......
Sooper's Avatar
Sooper
Bingo. Sensor on top of the rear diff. Easy to change, affordable part, and fixed the problem.
Old Mar 31, 2013 | 10:39 AM
zman17's Avatar
zman17
try the kick trick first, I'd like to know. And when if you decide to replace the sensor. Please disconnect the negative battery cable before doing so.
Old Apr 1, 2013 | 08:45 AM
zach01's Avatar
zach01
i have only one code and its a Evap leak code but i'll check into the rear abs sensor. cuz i'm have a kid due in a few months and i just wanna make my truck a little safe for with the wife drives it and this pass winter it wasnt very fun in the snow and ice when the brakes lock up..
