46rh to 46re
Old Apr 6, 2013 | 12:52 AM
69_XS29L's Avatar
69_XS29L
'94-'95 47RH and '96 up 47 RE LockUp and OD are both controlled by the PCM through the valvebody. I believe the biggest difference is that the governor ( and therefore line oil pressure to transmission components ) on the RE is controlled by the PCM. Is it not the same with small block transmissions? Good luck, Chango
Old Apr 6, 2013 | 01:01 AM
gdstock's Avatar
gdstock
A 47 Series tranny will not even bolt up to his 5.2L.
Old Apr 6, 2013 | 01:23 AM
69_XS29L's Avatar
69_XS29L
Then I guess what I am asking is: are the 46 series small block and 47 Cummins/V-10 differentiated in the same way? RH has solenoid in valve body for LU/OD and RE has PCM governor control in addition to that? I'm bidding some 4x4 wrecks at the salvage auction, would like to know. Good luck, Chango.
Old Apr 6, 2013 | 10:00 AM
That would be correct. 95 and older are RH, 96 and newer are RE.
