Wierd transmission problems
Old Apr 2, 2013 | 02:40 PM
98Ram5.9Sport's Avatar
98Ram5.9Sport
My cat is. I didn't think that that would have anything to do with the shudder though.
Old Apr 2, 2013 | 02:42 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You never know . Try (unsrewing) the precat o2 and see if anything changes.
Old Apr 2, 2013 | 07:09 PM
98Ram5.9Sport
Wouldn't doing that make it run like crap?
Old Apr 2, 2013 | 07:17 PM
stewie01's Avatar
stewie01
No.
It'll be louder, and you may set a CEL, just ignore it.
See how the truck drives.
Old Apr 2, 2013 | 08:33 PM
98Ram5.9Sport
Can I just unplug it or does it need to come completely out?
Old Apr 2, 2013 | 08:44 PM
stewie01's Avatar
stewie01
Needs to be completely out.
With it removed from the pipe exhaust will have somewhere to escape. If the cat is clogged you should see some positive difference in performance...
Old Apr 2, 2013 | 09:10 PM
98Ram5.9Sport
Okay thanks. I'll give that a try and see if it helps.
Old Apr 3, 2013 | 09:29 AM
Unplug it as well...... otherwise you will get some truly strange results.
Old Apr 5, 2013 | 02:14 AM
98Ram5.9Sport
I hate troubleshooting. I found a couple bad grounds today so in going to see if that fixes it. If not I'll get under there tomorrow to pull the o2 sensor.
Old Apr 9, 2013 | 10:36 PM
98Ram5.9Sport
So I fixed the ground issues a couple of days ago and I'm proud to mention that I have not had the shudder since. I still plan on replacing the cat eventually. Thanks for everyone's input.
