Delete trans lines from radiator?
Old Apr 2, 2013 | 08:13 AM
biker250's Avatar
biker250
Default Delete trans lines from radiator?
Hey guys, I've searched the forums high & low and haven't seen anybody talking about simplifying the auto trans cooling system, but I would love to remove the trans lines from the radiator. Is there an easy way to just run the pressure line from the trans straight to a cooler and then a return line from the cooler back to the trans and eliminate main engine radiator from the process???
Thanks.
Old Apr 2, 2013 | 01:20 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Cut the the steel lines, and run hose directly to the cooler.
Old Apr 2, 2013 | 05:55 PM
x2. Just make sure you use the proper type of hose.
Old Apr 2, 2013 | 08:13 PM
joshmopar's Avatar
joshmopar
And a large cooler.
Old Apr 2, 2013 | 09:38 PM
aofarrell2's Avatar
aofarrell2
All of the above is good... I've got a good cooler too if you need one.
Old Apr 9, 2013 | 10:02 AM
biker250's Avatar
biker250
Thanks for the info guys. jockey, what kind of cooler do you have?
Do you guys just hose clamp the hose to the cut steel lines? I would love to get rid of all my leaking quick disconnects....
Old Apr 9, 2013 | 10:29 AM
aofarrell2's Avatar
aofarrell2
biker250 I'll PM you about the cooler. As far as the lines clamping the hose onto it will be fine. I've done it and had no problems.
Old Apr 9, 2013 | 07:58 PM
dhvaughan's Avatar
dhvaughan
yes. cut the steel lines with a tubing cutter for a clean cut. use transmission hose and double clamp it since it doesn't have any barbs.
if you don't buy biker's cooler and want a super-duper cooler and can afford it, get the Tru-Cool 4739-1 LPD47391 40,000 GVW rating, 45,000 BTU.
its on the last page (round 3) of this thread.
https://dodgeforum.com/forum/2nd-gen...ter-added.html
Old Apr 11, 2013 | 05:37 AM
zach01's Avatar
zach01
my rad is by passed and i use the stock tranny cooler. and i tow a 24ft travel trailer and i also tow my 20ft car trailler with 7000-9000lbs pounds and ive never had my tranny get hot before even going up passes or on hot summer days...thats just my imput
Old Apr 11, 2013 | 05:10 PM
zman17's Avatar
zman17
One reason it run's through the radiator, is so the tranny get's up to optimum temp. Too cold and it will not shift to OD (as does too hot). The tranny need's to be a certain temp to operate correctly all around. Depending on where you live, there is such a thing as too cold and too big of an aftermarket cooler. Kind of like too cold of a thermostat.
