tranny help.....
Old Apr 9, 2013 | 08:30 PM
abrady3000's Avatar
abrady3000
Well i took the aftet market shifter off andfound the wires for the o/d they were cut and butt spliced together at one time. So my next question is..... when the wires are together the o/d is on? And when they are apart the o/d is off? Was told that this can also cause the trans to over heat. Not sure but would like to start from here and dig more if needed.
Thanks guys yall are a big help to a working class man.
Old Apr 9, 2013 | 08:58 PM
gdstock's Avatar
gdstock
I really don't want to go all the way out to the shop to look in the manual. When wires are together, is the OD light off or on? When they are apart is the OD light off or on?
When the light is on, OD is off.
And that will NOT cause tranny to overheat. Something else not working causes it to overheat.
Old Apr 9, 2013 | 09:29 PM
abrady3000's Avatar
abrady3000
im going to try and reinstall the old govern transducer this week end and see if i got a bad one. becaus i didnt have these problems till i installed the govern transducer and the siloned? spelling.lol
but this is what i found in the shifter https://www.facebook.com/photo.php?f...type=3&theater
Old Apr 10, 2013 | 10:45 AM
The O/D off button just sends a signal to the PCM. (momentary "ON" switch.) PCM then disables O/D, and turns on the light. With the wires tied together, I would think O/D would constantly be disabled.
Old Apr 28, 2013 | 03:48 PM
abrady3000's Avatar
abrady3000
well guys have some good news.... took out the transducer that i got from Dodge and want and got a Transducer from Napa put it in Friday and the transmission is shifting like it should and there are no trans. temp or O/D off lights on. so the problem was a bad transducer from Dodge.
Old Apr 28, 2013 | 04:01 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Congrats, it is quite possible you didn't have the plug in all the way too. But whatever, glad you got it solved.
Old Apr 28, 2013 | 08:01 PM
abrady3000's Avatar
abrady3000
I did drop the pan and checked all the connections and still had the same issues. But from the looks of it on this forum this is a trending issue with the Transducer being bad from MOPAR .
Old Apr 29, 2013 | 05:16 PM
zman17's Avatar
zman17
I've been here a long time, and have only heard of a prob with the OEM sensor here and now. So maybe it's as simple as, (God only knows) where the sensors are being made now.
