Engine ?
Old Apr 13, 2013 | 12:17 AM
ledman's Avatar
ledman
and why would you put a smaller motor in? Not like you are going to get any better gas mileage.
edit: just saw OP's post about the 5.2
Old Apr 13, 2013 | 12:19 AM
ledman's Avatar
ledman
Originally Posted by getdown78
I just found the 5.2 with low miles out of a wrecked truck ! All the 96-97 5.9s have over 150,000 miles and i just don't want to spend money and time swapping a motor that might last 6 months !
My '97 5.9L has almost 217,000 miles on it and runs STRONG. Shoot, 150k is nothing. And, where is the damage on the wrecked truck? There could be concealed damage to the engine from the wreck you may not see, does the engine run as it sits?
Old Apr 13, 2013 | 12:22 PM
getdown78's Avatar
getdown78
It was hit in the bedside and bent the frame and tore up the rearend is what the guy told me ! He said with a battery it would run ?
Old Apr 13, 2013 | 01:23 PM
ledman's Avatar
ledman
well I would get a batttery and try her out, I mean if it's a good deal, and the engine is sound, go for it. I unserstand budget constraints, so if this is the only option you really have, go for it! ...but again, the PCM may not be compatable like others have said, that part I really don't know about! GL
Old Apr 13, 2013 | 02:10 PM
Swap the intake manifolds, and the smaller engine will hook right up. It will run rich in open loop, but, aside from that, shouldn't be a problem.
